Losi xxx-4
Old 07-12-2004, 02:01 PM
  #466
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Can you even get step-pins all around? I thought the biggest tread losi made was the studs? Since we run 1/8 scale buggy on the same days as the electrics, step-pins could come in handy.
Cain is online now
Old 07-12-2004, 02:06 PM
  #467
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You can take a set of rear step pins and cut the center two rows out and glue them back together. It takes some patience and a carefull hand.
Jon Kerr is offline
Old 07-12-2004, 04:42 PM
  #468
LosiFromHell986's Avatar
woops! I meant studs... I thought they were called step pins...?
LosiFromHell986 is offline
Old 07-12-2004, 04:57 PM
  #469
or you can just glue some rear step pins on the front rims, it works fine if you have a decent servo.
Kave is offline
Old 07-12-2004, 05:16 PM
  #470
does it really work that well? wouldn't it make the front tires look bulbus?(<bulbus)
Old 07-12-2004, 05:45 PM
  #471
bulbus? Yes it works just fine, some people trim off the outer set of pins to take out some agression but yes, it works good
Kave is offline
Old 07-12-2004, 06:07 PM
  #472
hmm... I'll have to try that... thanks...
Old 07-12-2004, 10:29 PM
  #473
this may not be the best place to ask, but Jon, did you run a Swaybar at Family?
Old 07-14-2004, 10:38 PM
  #474
Ugh.... I hate waiting for a new RC... It seems like an eternity... I still haven't gotten mine!!
Old 07-14-2004, 10:50 PM
  #475
OvalEvader's Avatar
Cain - Some local guys are using an old kyosho tread in the front at our track. Its similar to a step pin, and its a very hard compound. I don't know the exact name, but they have them at the dollar bin at our local track, I'll try and look at the name next time I'm there.
OvalEvader is offline
Old 07-15-2004, 04:49 AM
  #476
Tech Legend
Cain's Avatar
Thanks for the info. I think I know what tread you are talking about.
Losifromhell: If you want to just get tires that are already setup for the front and rear ( no modifying ) I say give the studs a try. They really hook up great in conditions that step-pins are used at our track. Really great tire.
Cain is online now
Old 07-16-2004, 07:14 PM
  #477
Talking Got Mine!
Hey Guys, I got mine!
It doesn't look as Piss Yellow as in the first picture, it's actually flourescent yellow! The Bad news: Came with no motor mount, and I'm fresh out of cash. Also came without a Battery Strap...
I'm thinking of just using some Sheet Titanium and Making a motor mount. It's pretty simple, I could use holesaw in the right diameter and Make one pretty easily. As for the Battery Strap; I could spare 8 bucks for one.
So Here's my New Toy:
See? It's not piss-yellow!
Old 07-16-2004, 07:21 PM
  #478
Also:
It's clean now, I'm a clean freak with my R/C's!
Whoa these front shocks are tiny, compared to a truck! I've never owned anything other than a Truck, so this is all new to me. By the way, all the screws are IMPOSSIBLE to get out! Is there a reason for this? I stripped out one of my Drivers trying to move the Bellcranks back!
Old 07-16-2004, 10:31 PM
  #479
How big are the front shock bodies? I need Threaded shocks in the front, so I'm wondering what size to get. Also what size shock shafts? I'm planning on putting the whole shibang for front shocks as well.
Old 07-17-2004, 12:04 AM
  #480
Suspended
word of advice get a tc3 battery strap it works much better
offroadgod is offline
