Losi xxx-4
Old 02-03-2004, 03:46 PM
  #316
SlobbaTech's Avatar
My 4wd slipper had always fit tight into the chassis and works fine, never heard of one fitting in loose. If the slipper nut rubs the pulley tensioner arm then figure out how you need to shim the slipper differently so it doesn't rub and/or make sure you only have one of the shims inside of the belt pulley where the wave spring goes.
SlobbaTech is offline
Old 02-03-2004, 11:06 PM
  #317
aaronb73's Avatar
Yup, I took another look at it and sure enough the slipper nut was rubbing against the pulley arm. I had a bag of shims, threw one on with the other two that came with the kit... much better!
I've finished the front end and so far I've been very happy with how it's gone together. Can't wait to drive it!
aaronb73 is offline
Old 02-04-2004, 02:54 PM
  #318
Default xxx-4 one-way and a diff
I have made a one-way and a diff for the front of the car and was wonder if anyone else would be interested in it? it works just like the one-way that most everybody runs now except that it also acts like the normal diff action, should be better in the corners and also easier on the one-way bearings since you could put more stress on the diff and not on the one-ways, if enough are interested i might start making more of them, depending i figure cost should be around what the current one-way set is. It is made out of aluminum and plastic.
rschwartz is offline
Old 02-05-2004, 10:22 AM
  #319
Very interesting! I've been thinking the car needed this to. Do you have any pics to show?
Jeff P. is offline
Old 02-05-2004, 11:20 AM
  #320
i will have pictures after this weekend i am going testing and dont want to take it out of the car, there is only one prototype right now, but i have interest from racers in my area to make more.
Old 02-08-2004, 05:03 PM
  #321
SkipGear's Avatar
Schwartz ran his one-way diff for the first time last night at Planet RC. It looks promising. No major failures short of the diff looseing up once and some red loctite took care of that. It will need some setup changes to take full advantage of the difference in the way the driveline works.
Give it a little more tourture test time to see how it holds up but it seems to be working so far.
SkipGear is offline
Old 02-13-2004, 11:13 AM
  #322
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I tried the overdrive pully on my car last week. I was very impressed. I liked the more agressive feeling it gave the car. One other thing I noticed is the shock setups I've found that work are lighter oil w/ stiffer springs in the front and slightly heavier oil in the rear with softer springs. Seems to make it more reactive to steering but keeps the rear end under it. Anyone else find the same thing? I'm running 25wt/orange spring/ 57 piston front and 30wt.yellow spring/ 56 piston in the rear. The car really seems to like this shock setup.
Jon Kerr is offline
Old 02-13-2004, 12:52 PM
  #323
Wicked XXX-S's Avatar
Default Wicked's new XXX-4
Well it took some time but now I can add an xxx-4 to my sig. I bought it off ebay new but built and painted. So I have the body that came with it up forsale on ebay and just have to paint the new one I got in today.
THis is the body thats up on ebay.
I well update this weekend after I got the body painted.
Wicked XXX-S is offline
Old 02-14-2004, 11:07 PM
  #324
Here it is now painted.
Old 02-15-2004, 01:56 AM
  #325
aaronb73's Avatar
Losi finally released the green belt!
New belt for xxx-4
Supposively you can run it more loose and it won't skip, can't wait to try it
aaronb73 is offline
Old 02-15-2004, 09:04 AM
  #326
Jon Kerr's Avatar
Actually, from what I've heard the point of that was so you can run it tighter and still have a very free drive train. The new tensioner takes away the extreme kink in the belt and that frees things up a ton. This way, you can keep the belt tighter so you're not skipping the belt and still have a nice and free drive train.
Jon Kerr is offline
Old 02-15-2004, 12:50 PM
  #327
SkipGear's Avatar
aaronb73 - Losi finally released the green belt!
Huh?? The Green belt has been available for the car from day one. The new belt system is a change to a 2 bearing tensioner to help keep the belt from walking and as Jkerr said, revised geometry to make the kink in the belt less drastic and improve wrap around the drive pulley.
There is no new part number for a XXX-4 Belt. There is talk that there may be a running change to a .5mm narrower belt but there is nothing to confirm that.
SkipGear is offline
Old 02-15-2004, 01:19 PM
  #328
Jon Kerr's Avatar
Todd Hodge mentioned the running change on his thread I believe.
Jon Kerr is offline
Old 02-15-2004, 01:23 PM
  #329
Jon Kerr's Avatar
Anyone else switch to steel CVD's yet? The hole on the CVD for the retainer pin keeps streaching badly and soon just breaks on the aluminum ones. This happen to anyone on the steel ones too?
Jon Kerr is offline
Old 02-15-2004, 07:15 PM
  #330
Peter Busch's Avatar
Yep, the aluminum cvd's are crap unless you like buying new ones every month. Fortunatly the steel cvd's hold up really good.
Peter Busch is offline
