Losi xxx-4
Old 12-14-2010, 09:31 PM
  #2851
ChrisWolfson's Avatar
Finally dove in and started grinding. It turned out pretty well. I still have some work to do, but I'll get to try it this weekend...
ChrisWolfson is offline
Old 12-15-2010, 02:12 PM
  #2852
Looking Good
LittleGoob93 is offline
Old 12-15-2010, 07:50 PM
  #2853
Questions??
Very nice job of modifying but how is this going to affect the geometry?
The longer forward movement will give you more side to side movement and increased steering but won't it give you decreased ackerman? It looks like you are using the forward mounting position can you still use the back one to increase the ackerman if you want?
AlGio is offline
Old 12-15-2010, 08:40 PM
  #2854
This is a mod you will find on most of the TLR factory guy's cars. I don't think decreasing the ackerman is a bad thing. If your car was anything like mine, it was very twitchy and decreasing the ackerman, I believe should smooth that out since the inside tire shouldn't be turning as far as before in relation to the outside tire. Theoretically they should be closer to the same angle. I'm told the mod makes the car more stable from the middle of the corner off, which in my mind would make sense. This should let you drive the car harder and faster. As far as the mounting position, it is neither. It is a new mounting position outside of the back holes. It requires dremeling out the existing hex sections and creating a new set of holes. The bell cranks now sit wider than they did in stock form.
I'm really looking forward to running it this weekend. I just ran it in stock form last weekend, so I should really be able to compare the different setups.
Old 12-18-2010, 12:17 AM
  #2855
I wrapped up the steering mod today. Rack is done, posts are epoxied onto the chassis, and the front bumper is trimmed and tucked. I'm happy with how this project turned out. Took a few hours to get it done, but I'm looking forward to wheeling it tomorrow.
Old 01-18-2011, 05:48 PM
  #2856
DC#14's Avatar
What is a good kv to run in this car? I have a 5800kv do you think it would be fast enough?
DC#14 is offline
Old 01-19-2011, 12:17 PM
  #2857
I can tell you I run an Xcelorin 6.5 in my XXX4. You'll have to figure out comparables to that in kv. I'm not sure what the comparison is.
Old 01-25-2011, 04:15 AM
  #2858
BrodieMan's Avatar
I am in need of some new MIP front CVD dogbones, are they still available??? I just brought my XXX4 out of retirement to race indoor carpet off-road.
Hold up. where did you get those aluminum hubs Mr. Wolfson??? Are you using any mods to the front diff cover? I just cut the "ear's" of a broken shock tower and tap holes into the chassis and diff cover to put the little brace on. After breaking every heat at a new track I finally decided to do that mod lol! One more question for you; are you using the slipper?? I've been running a xxx-s spur instead and so far so good, even on a carpet track I haven't had any drive line breaks because of it. That slipper is a piece of (*&% IMO
BrodieMan is offline
Old 01-25-2011, 04:19 AM
  #2859
BrodieMan's Avatar
novak 7.5's are 5800kV, not sure if xcelorin are rated the same. I run a novak Velociti 6.5 in mine, it's faster than I will ever need.
Old 01-25-2011, 05:51 AM
  #2860
The cvd's aren't available anymore to the best of my knowledge. Most are using lcd's from Losi. The hubs are 0 degree bk2 hubs from trinity. They have been discontinued for some time but I've had them for awhile. You could check eBay and for sale threads for those parts. Sometimes you get lucky...
Old 01-25-2011, 07:44 AM
  #2861
JP.R's Avatar
Dang Chris that looks sweet! I have been wanting to run 4w for a while. Let me know if this mod really brings the car to life. If it does want to make me one.
JP.R is offline
Old 01-25-2011, 03:33 PM
  #2862
It makes a huge difference. I think it makes the car much more stable and able to hold a line from the middle of the corner off. The old steering usually felt more like I had to baby the car coming off the corner. This let's me drive the car more aggressively. I'm a big fan...
Old 01-25-2011, 04:28 PM
  #2863
J. Schwarz's Avatar
Trader Rating: 51 (100%+)
Looks great, just picked up a second hand xxx4 myself and am busy going though her trying to get her back to running shape. hoping to perform this mod while i have her stripped. Does not look like too tough of a job.
I am sure it has been covered but, quick question.
Have an Orion Vortex Race Spec ESC and Vortex 6.5T motor. Car has the 92T in it. I have a handfull of pinions from 17T thru 20T, what do you recommend as a starting point?? Thanks
J. Schwarz is offline
Old 01-25-2011, 08:39 PM
  #2864
What kind of track? Surface? Size?
Old 01-30-2011, 06:18 PM
  #2865
What do you have to do when it comes down to the front bumper mod. When you say trim and tuck the bumper? I just want to make sure I do it correctly. Thanks
hitordie010 is offline
