Losi xxx-4
Old 09-07-2010, 10:22 AM
  #2836
NOFX's Avatar
Trader Rating: 25 (100%+)
Originally Posted by desert truck 1
HELP, was searching this thread for an answer to a gearing problem...all I found was the same question with no answer.
Is it that you have to run the xxx-s spur moulded shape as a mod ...no slipper?
HELPPPPP?
yeah run the xxx-s spur, then run the smaller pulleys (41T the ones with the dot on them) front and rear, this means your internal ratio goes from 42/20 = 2.1 to 41/23 = 1.78 so with the 88 spur you can easily get to the ratios required for 17.5 racing and you also dont need to modify anything, u gain 3 teeth on the centre pulley, lose 1 on each diff so the tensioner can cope with the 1 tooth variance and running no slipper isnt a problem in 17.5 racing
NOFX is offline
Old 09-07-2010, 02:15 PM
  #2837
BrodieMan's Avatar
I've been running the xxx-s spur for a while now and I haven't had any issues. Using the smaller pulley in front and aluminum outdrives all around. There isn't a lot of big jumps where I run but have heard the belt tension pulley can break sometimes on rough tracks when not running a slipper. Even so, not having to deal with that slipper is well worth the risk.
BrodieMan is offline
Old 09-15-2010, 04:09 AM
  #2838
desert truck 1's Avatar
Default 1-way or another
Got around the gearing issues, thanks...now I am running a one-way in front...need to get some new outdrives for a one-way, any ideas where to purchase these?
desert truck 1 is offline
Old 09-15-2010, 07:38 AM
  #2839
Briguy's Avatar
Trader Rating: 125 (100%+)
Horizon , Losi Parts house , and your LHS .
Briguy is offline
Old 11-25-2010, 01:01 PM
  #2840
240zron's Avatar
Trader Rating: 30 (100%+)
I just received a Losi xxx4 and have been looking at putting a one way in it. When i look for one it shows a left side part number, and a right side part number. Are both of these needed? seams like I read somewhere that the xxx4 uses only the right side. Is this correct? (probably not) And where is the best place to buy one? I have been reading the Losi one is junk, is that true?
Also I have had it at the track a few times, and for some reason it keeps throwing the belt. I have had several people try and tension it, and for some reason keeps throwing it. Everyone that I have talked to that has a xxx4 says they haven't had this problem. I have pulled the entire drive train and checked all the bearings, ect... and have found no problems. I'm running a 10.5 motor in it.
Thanks for any help you can provide.
240zron is offline
Old 11-26-2010, 06:47 PM
  #2841
ChrisWolfson's Avatar
I'll try to help you...
First - forget the one way. You don't need it. the Losi one-way was originally designed for on-road and it just doesn't hold up to the rigors of off-road racing. Team drivers are running diffs in their cars. I have a one-way made by a british company that I fitted into the car that solved the durability issue. I still don't run it - way too much steering.
Second - are you using reverse in your buggy? If so, that is probably throwing the belt. It's not meant to go backwards. If not, make sure you have the right belt and it's not overly stretched out. You may just want to replace the belt if that's the case.
ChrisWolfson is offline
Old 11-30-2010, 03:52 PM
  #2842
Trader Rating: 41 (100%+)
Default losi esc
could i ask for someone who is running a xxx4 g+ to post or send a pic to me of how they have there losi esc mounted in the vechile i cant really see a good way to mount it and the compaciter and i hate to run a diffrent esc any help would be cool thanks for looking
tntchance is offline
Old 11-30-2010, 04:52 PM
  #2843
Here you go... It actually fits really well - fan and all...
I love this car!
Old 11-30-2010, 08:57 PM
  #2844
Awesome thanks for the help that is what one option was I came up with I just was not sure if servo tape would hold the cap good if I took a hard hit or bad jump thanks alot the pics really do help
Old 11-30-2010, 09:40 PM
  #2845
I love this car!
Car looking fresh Chris.
Have you ever tried the steering rack?
LittleGoob93 is offline
Old 11-30-2010, 10:20 PM
  #2846
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Are they just worn out tyres on the rear of that ChrisWolfson or is that slicks your using?
Drift_Buggy is offline
Old 12-01-2010, 01:08 PM
  #2847
Funny you ask - I'm actually dremeling away on a chassis right now and have already fabricated the rack out of carbon fiber. I will be trying the rack very soon! I just have to finish the fabrication work and then bolt the components onto the new chassis.
Old 12-01-2010, 01:10 PM
  #2848
Those tires are not worn out - we run slicks made from Pink Taper Pins at our track in western PA. www.mcculloughsrcracing.com. I usually run slicks on the front, but the tires on there now were used to tame down the steering a little bit. It worked very well, actually.
Old 12-01-2010, 01:23 PM
  #2849
Briguy's Avatar
I take it you never raced on a hard packed clay track ?
Briguy is offline
Old 12-03-2010, 04:10 PM
  #2850
I actually like the steering rack a lot. I saw a big difference, I dont know if anyone else did but it felt a lot better with the rack.
