Losi xxx-4
Old 04-28-2009, 08:33 PM
  #2581
Armstrong's Avatar
Trader Rating: 18 (100%+)
Thanks for the link . I'll probably stay with plastic for now though. I'm already using aluminum braces all over and doubled up shock towers so there might be a lack of a weakpoint in the front end that will give if ever I get into a serious crash.
Another question, I've heard that the carriers are weak in the XXX-4 although mine have survived some serious crashes already. Where exactly does it break?
Armstrong is offline
Old 04-28-2009, 09:46 PM
  #2582
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Armstrong
This is good too. The only down side is probably the posts sticking out of the body. But I like the fact that it is adjustable which is helpful if you have different batt packs.
Yeah, I trimmed down the front post a bit. I also need to put some Velcro on the battery as a 2nd secure method from it sliding around.
y2kgtp is offline
Old 04-28-2009, 10:21 PM
  #2583
JeromeK99's Avatar
The front carriers and spindles do break when you clip a wheel sometimes... no more often than any other 4wd out there. This happens more when you have the updated graphite (crossbraced) arms. They break where the hinge/screw holds to the arm.
Jerome
JeromeK99 is offline
Old 04-29-2009, 08:08 AM
  #2584
Jerome
Yup, I was screwing around in practice on sunday, cliped the plastic pipe and blew up the carrier.
I've had my xxx-4 for about 2-3 months and I've probably broken 4 carriers.
Toddzilla is offline
Old 04-29-2009, 05:55 PM
  #2585
JeromeK99's Avatar
As I've said before, we have just about every 4wd out there racing at our local track. When racing modified, every car can and will break. The XXX-4, contrary to the "Net Parrot" that squawk about how "fragile" they are... are wrong.. I'm one of the few that run the XXX-4 around here and it hardly breaks at all... I've been on the same belt and gear set for close to a year now... I've broken a couple of shock towers, a few spindles and carriers and a front cvd axle in a years worth of racing. I'd say that's not so bad.
The XXX-4 is a tough old girl. Takes a bit of tuning and know-how to get her to handle good.. but its still competitive.
Jerome
Old 04-29-2009, 06:12 PM
  #2586
Alltapdout's Avatar
+1
I use J Concepts front carriers.
Alltapdout is offline
Old 04-29-2009, 06:40 PM
  #2587
Jerome
I agree, my car has taken a great deal of punishment.
Old 04-29-2009, 09:27 PM
  #2588
Armstrong's Avatar
I guess I have to stock up on a few spare sets of spindles and carriers. That's probably the only part left that's prone to breaking in my buggy provided I don't do anything stupid like dive bombing other guys .
In the king pin mod, I understand that you need to drill larger holes to the front arms. Won't they make the arms weaker that way?
Any link to those J-concepts carriers? Are those the ones that come from BJ4s?
Old 04-30-2009, 01:16 PM
  #2589
xBRxSAIGON's Avatar
[QUOTE=JeromeK99;5749583]As I've said before, we have just about every 4wd out there racing at our local track. When racing modified, every car can and will break. The XXX-4, contrary to the "Net Parrot" that squawk about how "fragile" they are... are wrong.. I'm one of the few that run the XXX-4 around here and it hardly breaks at all... I've been on the same belt and gear set for close to a year now... I've broken a couple of shock towers, a few spindles and carriers and a front cvd axle in a years worth of racing. I'd say that's not so bad.
Yes i'm sick of all the trash talk about the xxx-4 at my track. Losi is all I have and ever will run... The XXX-4 with the proper setup and driver is most deadly 4wd out there period. It is belt driven and weighs almost a whole pound less than the b44 w/out batteries in either buggy. I do get tired of breaking mine sometimes BUT the performance is second to none
xBRxSAIGON is offline
Old 04-30-2009, 03:07 PM
  #2590
All The Way's Avatar
The ones from a main work flawlessly... the link is up above or prev page
All The Way is offline
Old 04-30-2009, 07:35 PM
  #2591
Alltapdout's Avatar
http://www.jconcepts.net/store/index...75ef6c40af1234
I'm sure the amains would work flawlessly....If they were ever in stock
*Edit* Alright, actually they are in stock, but I've had this rig for over 4 years, and those things were never there, I even called for like 6 months....nothin. So if anyone is interested in the AMR products..I recommend not waiting to purchase. My 2c
Old 05-04-2009, 10:24 AM
  #2592
Armstrong's Avatar
Thanks for the links. I'll try those if my stock ones break.
Old 05-04-2009, 12:11 PM
  #2593
RCHR's Avatar
Could anybody tell me what the a starting place for a 10.5 motor gearing would be for a small indoor track.
Also the output gear ratio of the xxx-4 transmission.
RCHR is offline
Old 05-04-2009, 07:17 PM
  #2594
Trader Rating: 84 (100%+)
also what are people gearing the xxx-4 with a 5.5?
jeff jenkins is offline
Old 05-04-2009, 08:12 PM
  #2595
Im running 18 92 with a 6.5, gives ya something to go off
