Losi xxx-4
Old 03-26-2009, 01:41 PM
  #2446
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Toddzilla
Do you have a part number on those posts?
That looks ideal.
losb1036
http://shop.ebay.com/?_from=R40&_trk...All-Categories
I have a couple more sets laying around of someone needs\wants to try it out as well. I noticed the strap is very snug on the posts, and might need a slight enlargement of the hole to come off easily.
y2kgtp is offline
Old 03-26-2009, 06:57 PM
  #2447
All The Way's Avatar
Im a 2wd truck guy and I didn't like the one-way... I run LCD's and it's a lot better, just have to do some work to keep them together.
If you need the car to rotate a little more the xxx cr rear arms and hubs help. I use both cr and bk2 arms as a tuning option.
All The Way is offline
Old 03-26-2009, 07:19 PM
  #2448
xDaRReLLx87's Avatar
Originally Posted by y2kgtp
I am going to look for a new strap as well.
From what I understand on the one way, it's better for larger, less technical tracks. Under power it will make the car push a bit more as it technically is a Spool and you don't have any differential action.
With the stock diff under hard breaking you might lock up the front and cause push going into a corner as well.
I guess it all depends on your driving style....I put mine in as I'm used to 2WD, so thought it might help me in that respect, but I am thinking I might put the stock diff back in and try that first.
At least I'm ready to go for either one I want to try out.
Try using Velcro on the battery along with Velcro straps to ensure battery does not move to much, along with your so called solution
xDaRReLLx87 is offline
Old 03-26-2009, 10:01 PM
  #2449
tkge's Avatar
Trader Rating: 123 (100%+)
Anyone have any issues with the slipper flange coming loose? I tighten it down pretty good, but it seems to loosen up when I run...any ideas or should I just get a rebuild kit?
Thanks!
Tim
tkge is offline
Old 03-27-2009, 08:53 AM
  #2450
y2kgtp's Avatar
Well, local racers at my track say no to the 1-way, so the stock ball will be going back in.
Do they make a lexan undertray for this buggy? I would like to seal off the battery area of the chassis if I could underneath.
y2kgtp is offline
Old 03-27-2009, 11:11 AM
  #2451
y2kgtp's Avatar
I got my Trinity aluminum rear hubs in I bought off of eBay (2 degree) but they don't have the same markings as the set I have installed (2L & 2R)
Is there a way to decrease the toe-in on the car itself, other than the rear hubs? Here is the photo again of what the hubs look like. They look very durable, so would like to keep them on the buggy.
I bought this 2nd pair intended to go on my Speed-T
y2kgtp is offline
Old 03-27-2009, 04:42 PM
  #2452
y2kgtp's Avatar
Looks like I need 4-4.5oz of weight on the battery side....any ideas?
y2kgtp is offline
Old 03-27-2009, 05:58 PM
  #2453
ShtLuck's Avatar
Trader Rating: 45 (100%+)
i found a set of 0 degree hubs like that at my hobby shop today... got them for 12.00 bucks cause they had been sitting there for a few years and i got a set of trinity kinwald pro shock mounts with the delrin bushings....
ShtLuck is offline
Old 03-27-2009, 06:54 PM
  #2454
Thanks!
Tim
loctite then crank tight...
Old 03-27-2009, 07:41 PM
  #2455
jrr102486's Avatar
+1 on the loctite, but remember, a little loctite goes a long way
jrr102486 is offline
Old 03-27-2009, 09:06 PM
  #2456
y2kgtp's Avatar
zero degree? What is the part number?
y2kgtp is offline
Old 03-27-2009, 09:25 PM
  #2457
ShtLuck's Avatar
part number is tk5102
i will get some pics up as soon as i get it all together
ShtLuck is offline
Old 03-27-2009, 10:21 PM
  #2458
y2kgtp's Avatar
I could swore I posted the setup sheet that came with my hubs ....
y2kgtp is offline
Old 03-28-2009, 10:58 PM
  #2459
big greg's Avatar
Trader Rating: 119 (99%+)
so i got to drive the car today. it ran very good, lets just say with the 6.5 in there i was hitting jumps that my 8th scale was making! all i broke was a ball stud and a rear hub, this is after NUMEROUS times in the wall, this things a tank. i woulda been 10th in the A but won the B then bumped up, made it a lap and then the hub broke lol, i was happy since its my first time runnin 10th 4wd
big greg is offline
Old 03-28-2009, 11:09 PM
  #2460
y2kgtp's Avatar
What 6.5T are you running?
y2kgtp is offline
