Losi xxx-4
Old 03-23-2009, 04:54 PM
  #2386
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Originally Posted by pyro18t
You have fun with that one... let me know too because I have 8.5T also
J
Can...you ...count ...the ...pinion ...teeth?
On a side note....ideas on the battery side? I could fit 2 LiPo's in the height I got in this thing.... They need some more adjustments on the posts.....
y2kgtp is offline
Old 03-23-2009, 07:17 PM
  #2387
JeromeK99's Avatar
Originally Posted by y2kgtp
Ehh..I threw a 16TG in there so I could mount the motor...
I run a 7.5 in mine and run a 19t with the stock spur. At 16t it ran hot all the time. The thing came to life when i geared it up more and rarely goes over 110 degrees.
One thing I notice when I first started playing with brushless is that gearing rules are not the same as brushed motors (beyond just running lower FDR). When you gear up for more speed, you also gain a big amount of low end torque. I believe that this is due to allowing the motor to spool up in rpms to a better powerband quicker than under the lower gearing load.
Jerome
JeromeK99 is offline
Old 03-23-2009, 11:38 PM
  #2388
verticalpilot's Avatar
Trader Rating: 18 (100%+)
You guys know where I can get a one way diff for the front? Seems mine is pulled from the front or the back is too loose to push the car through the turn.
I also am using 5700kv mamba max motor, it's got tons of torque but the power comes a bit slow / or at higher motor rpm. I'll change the gearing to lower pinion and play with the mamba settings, but now the motor is way too hot (I ran 23/ 92). I'll try 19/92 next or lower to 16/92.
I set to pudge setup w/ holeshot tires, but it's not to my satisfaction. Any advice is appreciated, thanks.
verticalpilot is offline
Old 03-23-2009, 11:50 PM
  #2389
big greg's Avatar
Trader Rating: 119 (99%+)
glad your car came y2k, i just put my lrp 6.5 in it, im running it non sensored off of the ez-run 60 amp speedo, its super smooth off the start im suprised, i put a 20t pinion on there, i would try a 21-22 for you, this things a rocket tho i might have to gear down lol
big greg is offline
Old 03-24-2009, 07:00 AM
  #2390
Trader Rating: 29 (100%+)
y2kgtp check pm
taztal3 is offline
Old 03-24-2009, 07:50 AM
  #2391
y2kgtp's Avatar
Originally Posted by taztal3
y2kgtp check pm
Replied...thanks.
I got a NIP 1 way with my XXX-4, it is part number A3245 It is marked for the XXX-S, but obviously it works for the XXX-4 as well.
http://www.xfactoryrc.com/storelosi.htm = on backorder
eBay = 59.03 Shipped (5 in stock)
http://cgi.ebay.com/Losi-A3245-One-W...3286.m20.l1116
58.09 + ship
http://www.losipartshouse.com/servle...r-Drive/Detail
60.99$ shipped
http://cgi.ebay.com/Losi-One-Way-Fro...3286.m20.l1116
Damn, I got a good deal on this buggy
y2kgtp is offline
Old 03-24-2009, 08:11 AM
  #2392
y2kgtp's Avatar
Who makes these rear hubs? I thought they were GPM prior to me getting the buggy, but they have more of a CR geometry. They even have a setscrew to hold the pin.
I think they are Trinity.
y2kgtp is offline
Old 03-24-2009, 10:35 AM
  #2393
y2kgtp's Avatar
I scanned my one way instructions if anyone is interested. It also lists the individual part numbers in case you wanted to piece it together perhaps?
I have a larger scan available if you want to PM me for it, but this should do for most.
It looks like the most expensive parts are the hub\1 way bearings...
y2kgtp is offline
Old 03-24-2009, 11:13 AM
  #2394
big greg's Avatar
man those rear hubs are nice. i like the fact they have set screws in em, keeps them from getting wore on the hingepin
big greg is offline
Old 03-24-2009, 11:17 AM
  #2395
y2kgtp's Avatar
There was 1 set on eBay (I just bought them), and I can't find them anywhere else.
The eBay ones were labeled 2 degree toe in...I do not know what degree I have installed.
y2kgtp is offline
Old 03-24-2009, 12:39 PM
  #2396
DHC6's Avatar
Hey guys, I was just wondering if any one has put a Hard case Lipo in their XXX-4 yet? I just a few a and it seems I will have to trim the chassis to get them in. Just wondering if any one else has done this or is there an obvious solution that I have over looked?
DHC6 is offline
Old 03-24-2009, 12:46 PM
  #2397
Phelps's Avatar
y2kgtp, those are Trinity hubs. Hopefully they are 1 degree ( should have 1 dash on the side). The XXX-4 comes stock with 2 degree inboard toe and 1 degree hubs for 3 degrees total. The 2 degree hubs were for the gas truck and will be over kill on the XXX-4.
Phelps is offline
Old 03-24-2009, 12:53 PM
  #2398
y2kgtp's Avatar
Ugg...they are marked 2L and 2R I did not notice at first.....
I have all the aluminum rear pivots that came with the buggy. It currently has a 3R/-1R with the 3R right side up. Does flipping this give me -1 degree? I also have a rear marked 1R as well.
y2kgtp is offline
Old 03-24-2009, 01:26 PM
  #2399
Matt Howard's Avatar
It takes about 15 minutes of light dremel work to get a hard case lipo to fit in a XXX4
Matt Howard is offline
Old 03-24-2009, 01:31 PM
  #2400
y2kgtp's Avatar
or 5 minutes of heavy.....
y2kgtp is offline
