Losi xxx-4
Old 03-01-2009, 10:30 PM
  #2296
verticalpilot's Avatar
Trader Rating: 18 (100%+)
Hey guys,
I just started xxx4, and I talked w/ local Losi guru who told me 4wd losi isn't very stong. Anyone have different opinion? I don't doubt our local track Losi 'master', but what are the finer points that puts xxx4 below b44?
Thx.
verticalpilot is offline
Old 03-01-2009, 11:37 PM
  #2297
frankiecmgt's Avatar
Trader Rating: 77 (100%+)
well after running a few ( and still running one ) over the past 9 years this is what i found..
1. double up on the front shock tower
2. the front carriers are weak..i run the bj4 ones
3. the front outdrives snap easy..i run steel ones all around
4. front hing pin brace..if you can find one get the 7.5 it's the best one for the xxx4
5. the rear shock tower..double up on that to
6. run the yellow belt if you don't have it already
7. the front aluminum cvd's are also kinda weak
other than that it's a great buggy. hope this helped out and welcome to the fragele world of 4wd buggy....
frankiecmgt is offline
Old 03-02-2009, 02:16 AM
  #2298
JeromeK99's Avatar
At our local track we have just about every 4wd out there racing... XXX-4, XX-4, B44, BJ4, ZX-4 (all versions), D4, Yokomos, Tamiyas and more....
We race'em modified like intended! To tell you the truth.. they all break... Sometimes its just a tap of another car or a pipe.. other times its a hard tumble or smack.
I had one of these years ago when they first came out... and now again I have another I have been racing for awhile now.. It is a good, stable car. The upgraded yellow belt on my G+ is going on over 6 months of racing...
Mod power can break anything... but as much as everybody seems to have such a bad opinion about the XXX-4 mine has taken some serious tumbles and crashing.. but it doesn't break anymore than the others seem to.
The XXX-4 can still compete.. it might take a skilled driver and experienced mechanic to set it up correctly out of the box though...
Jerome
JeromeK99 is offline
Old 03-02-2009, 05:45 AM
  #2299
Trader Rating: 24 (100%+)
I agree with a lot of the recent suggections, but I see no point to doubling up either of the shock towers. I have cracked a few of the rear towers, but even when it cracks, it is still in one piece, just "bent".
I went to a track this weekend with the xxx-4 and broke the front diff cover (that happens now and then), then one or two of the B44 drivers talked about how their car did not break for the last 12 weeks. I was thinking, "Hey, that's great, maybe I will switch over." But then I saw his front A-arm and front top chassis plate break soon enough. So I am kind of back to neutral.
I think the best durability areas are
1) the front 7.5 hinge pin holder -> aluminum,
2) front caster hubs -> aluminum,
3) maybe the special mod that straps the lower end of the front diff cover to the chassis (haven't tried that one, but can imagine the benefit).
That's about as far as I would take it, but keep spares of the front inner hinge pin mount
BobWoodhouse is offline
Old 03-02-2009, 07:27 AM
  #2300
I was wondering what mod are you talking about strapping the lower end of the front diff cover to the chassis.
I just picked up a XXX-4G+ to run at our local track. The first weekend with it the car had a few breaks, but it wasn't without a cause. There was a half pipe wall turn that killed me the first time out, that continued to have a impact on me throughout qualifying with a parts list of front belt cover, left hub, left wheel nut. But during main time it all started to work out and had a second place finish with Alleged old and outdated XXX4.
Jammin_Xtream49 is offline
Old 03-02-2009, 12:38 PM
  #2301
I was searching for the article, but could not find it. You take a small rectangle of carbon fiber or something say about 1/4" by 1/2" and put one on each side of the chassis where the diff cover and chassis meet, just under the outdrive bearing. Then put a screw in each end of the rectangle to secure the diff cover to the chassis.
Old 03-02-2009, 06:32 PM
  #2302
Johno's Avatar
hi guys
Just wondering what would be the best pinon to run in the xxx-4
it has a 94 spur gear and will be running the Tamiya black can motor
Johno is offline
Old 03-02-2009, 08:40 PM
  #2303
zippy_91's Avatar
Trader Rating: 29 (100%+)
What's the part number for the steel outdrives for the front? I'm trying to make it a little more durable before the season begins.
zippy_91 is offline
Old 03-02-2009, 10:09 PM
  #2304
jrr102486's Avatar
same as the rear. i used xxx-cr buggy ones when the rear outdrives were on back order.
jrr102486 is offline
Old 03-02-2009, 11:49 PM
  #2305
Thanks everyone for the feedback.
I'm sure to have fun with it just as I'm having good times with XXX CR.
Now I ain't afraid of those B4s or B44s.
Old 03-03-2009, 06:01 PM
  #2306
All The Way's Avatar
I have the pic for those cf parts somewhere...I burned mine out of .100 stainless
All The Way is offline
Old 03-04-2009, 09:15 AM
  #2307
I had a question on bodies, which one has the the most room underneath it. The original Invader or the Aurora.
Old 03-04-2009, 01:40 PM
  #2308
jrr102486's Avatar
they are both about the same but i like the lines better of the aurora.
Old 03-04-2009, 03:42 PM
  #2309
JeromeK99's Avatar
The Invader has more room than the Aurora... I run a Novak GTB, which is pretty big, the Aurora didn't fit....
Jerome
Old 03-07-2009, 03:04 PM
  #2310
anyone have read my question ? let me know it
taztal3 is offline
