Losi xxx-4
Old 11-12-2008, 05:20 PM
  #2251
Super Moderator
More steering is something I am looking for. I'm going to try it next time
roadrashracing2 is offline
Old 11-12-2008, 07:54 PM
  #2252
losi guy's Avatar
Trader Rating: 38 (100%+)
A oneway will give you lots steering. I needed more steering and it made a big difference.
losi guy is offline
Old 11-25-2008, 06:01 AM
  #2253
NOFX's Avatar
Trader Rating: 25 (100%+)
hey dudes, ive got some setups out of this thread from some very helpful people and i also found steenaris setup for the car that he came up with, its on the losi boards website, i'll probably run it without the one-way but my question is the pistons he has showing on the front is 667 and rear is 442, im assuming its some kind of drilled piston but anyone know what it means, ive put the website just in case and theres only on steenari setup for the xxx4
thanks
http://www.losiboard.com/offroad.html
NOFX is offline
Old 11-25-2008, 10:55 AM
  #2254
I've got a Q. Is the graphite chassis the only chassis you can get for the XXX-4? I am picking up an old one today, and it has a broken chassis. Just want t make sure there isn't a plastic one before I go and spend what is over $100NZ
JR007 is offline
Old 11-25-2008, 11:46 AM
  #2255
Eccentric's Avatar
The graphite chassis is the only one currently available. The plastic chassis was available for a long time after the G+ came out (and cost half what the graphite chassis did), but it has been discontinued.
Eccentric is offline
Old 11-28-2008, 02:00 PM
  #2256
Trader Rating: 46 (98%+)
Pheeew Finally got a roller almost set-up after taking apart 2 complete xxx-4 and making one nice roller and making a bin of extra parts. Now I have a few questions hope yo guys can answer.
The manual shows the rear shocks mounted behind the rear shock tower. My buddy just picked up a a xxx-4 that was owned by a guy who worked at a hobby shop and was really detail oriented. When putting my roller together I was using his xx-4 as a base. I noticed his shocks were mounted on the front side of the shock tower. In order to do this you needed to add a little extra spacer onto the uper shock mount. Well I set it up like so but am just not sure if this is a good setup. When doing this I also moved the 2 little shims on the hub carrier to the front just like his xxx-4 im assuming this is for a little more chassis length.
The other question I have is on the steering. I notice you have to options when mounting the steering post. Closest to the nose or one notch back. Which is a better set-up?
everyjuangohome is offline
Old 11-28-2008, 05:30 PM
  #2257
JeromeK99's Avatar
The original XXX-4 had plastic shock towers and you would run the rear shocks on the front side... they then made "graphite" upgrade towers molded exactly like the plastic versions. Finally with the G+ set-up they made a cut carbon fiber (graphite) shock tower (both front and rear). With these you run the rear shocks to the back.
You can still get both manuals and exploded views from http://www.losi.com
Jerome
JeromeK99 is offline
Old 11-29-2008, 07:53 PM
  #2258
Thanks. Got the shock situation all figured out. Do ou guys run any limiters in the front shocks? at full droop my steering knuckles hit the lower arm when turned?
Also I just wired it up and had the wheels free spinning. I was giving it some gas then would hit the brakes to test out my connections did this twice and the belt snapped? WTF does this happen alot could my belt have just been old? It makes a wicked snap when you hit the brake
Old 11-30-2008, 12:20 PM
  #2259
It actually broke? Or just made a snapping noise? What color belt are you using?
Tater salad is offline
Old 11-30-2008, 02:20 PM
  #2260
The belt was black, and yes that bastard BROKE LOL
I have a belt on my older xxx-4 that is green. I was pretty sure the new HD belt's were black, or yellow. I was suprised it actually snapped!!
Old 11-30-2008, 02:30 PM
  #2261
Briguy's Avatar
Trader Rating: 125 (100%+)
Hhmmmm , I don`t even remember a black belt . Must be one of the originals .
Briguy is offline
Old 11-30-2008, 03:18 PM
  #2262
I think the green was the OG then Ive seen a HD belt in black and Yellow. It not looks like the HD belt is Yellow. I ordered 2 up and hope I have better luck.
Now about the front shocks are you supposed to run some limiters inside them?
Old 11-30-2008, 04:02 PM
  #2263
frankiecmgt's Avatar
Trader Rating: 77 (100%+)
RUN THE YELLOW BELT AS THAT IS THE HD ONE. THE BLACK BELT IS FROM THE ON-ROAD VERSION OF THE XXX4 ( XXXS ) THAT BELT WAS NOT MADE TO RUN OFF ROAD AS IT IN A WEAKER BELT. THE ORIGINAL XXX4 CAME THROUGH WITH A BLUE AND THAN A GREEN BELT. HOPE THIS HELP'S...FRANKIE
frankiecmgt is offline
Old 11-30-2008, 04:34 PM
  #2264
I would start with .060" and go from there. The yellow belt is good.
Old 11-30-2008, 05:53 PM
  #2265
MD
MD's Avatar
Trader Rating: 136 (100%+)
There is a yellow belt for the XXXS. That is a hop up for the XXXS. I don't know if they make a yellow belt for the xxx4, which is different.
MD is offline
