Losi xxx-4
Old 10-30-2008, 11:16 PM
  #2221
Trader Rating: 65 (100%+)
Default gearing
i just took my xxx4g out for the third time. i guess my gearing is off. i am runninging sidwinders esc and 57k motor. problem is after like four mins the thing shuts off. my guess is its getting to hot. running 3s 3700 lipos. what is the correct gearing to run? new to new age electic stuff, use to old brushed motors and gearing. i bought this used and am pretty sure it hase 93 spur gear. not sure about pion gear have not taken motor out,. need to race sat though. sick of all local guys bad mouthing the king of electric losi lol. i can run with the best utill this thing shuts off from getting hot. if anyone can help i would love it thanks guys
mixedguy is offline
Old 10-31-2008, 09:57 AM
  #2222
Super Moderator
roadrashracing2's Avatar
Go up a few gears, or go to a smaller spur. Whats the temp when it stops running? Is you belt tension to tight?
roadrashracing2 is offline
Old 10-31-2008, 12:25 PM
  #2223
Matt Howard's Avatar
mixedguy- The problem is you're trying to race with a 3s lipo pack, that's gonna be too much voltage making the car very fast and overheating your esc as well. If you absolutely want to run that pack then go smaller on the pinion gear until the temps come down to where it isn't overheating.
Matt Howard is offline
Old 11-01-2008, 05:42 AM
  #2224
shadow102's Avatar
Trader Rating: 21 (96%+)
Hey guys just wondering if there was a xxx4 faq or something. I am getting one next week used and this will be my first 4wd buggy and really the first car I will race offroad. Just looking for needed upgrades and what to look for.
shadow102 is offline
Old 11-01-2008, 09:23 AM
  #2225
F N CUDA's Avatar
Trader Rating: 34 (100%+)
If you smack the front end on this car you are gonna need some new parts like front diff covers and hingepin supports, shock towers (just keep changin em, don't beef em up or you will break the chassis instead) but other than that stuff it is a fast and fun car.
Drive it carefully til you get used to it, motor down and you will have lots of fun. Motor up and you will have even more fun but you will crash and break parts just like any other 4wd buggy.
More than enough info in this thread to get you what you need, lots of good reading.
F N CUDA is offline
Old 11-01-2008, 01:50 PM
  #2226
Super Moderator
I am running lipo on mine, do I need to add weight
If so how much and where.
Old 11-01-2008, 03:02 PM
  #2227
You'll need to add weight to the battery side to balance the car from side to side. If I remember right I added just under two ounces to the battery side to get mine balanced.
Old 11-01-2008, 09:09 PM
  #2228
NOFX's Avatar
Trader Rating: 25 (100%+)
exactly, u can get the aluminum pivot supports which are stronger, but if u smack the car (any car) hard enough, something will break, better an arm or tower, oh get spindles and carriers too, ive done a few of them, but that advice of motor down, learn to drive it is the best, by design, the thing is very efficient in the drivetrain and its light, so it accelerates like a monster and has great top speed
NOFX is offline
Old 11-03-2008, 08:00 AM
  #2229
shadow102's Avatar
Anybody still make bodies for the xxx4? Is the factory losi one the only choice?
Old 11-04-2008, 04:00 AM
  #2230
NOFX's Avatar
Anyone got a setup for the xxx4 so it drives like my xx4 we kit setup (stenari setup)
NOFX is offline
Old 11-04-2008, 08:14 AM
  #2231
jrr102486's Avatar
losi is your one and only choice. i dont think anyone else ever made one besides losi for the xxx4
jrr102486 is offline
Old 11-04-2008, 03:48 PM
  #2232
Trader Rating: 24 (100%+)
Ijust received this video of my track. There is my xxx-4 tooling around the track.
http://www.youtube.com/watch?v=Qvz9BydL0ls
BobWoodhouse is offline
Old 11-04-2008, 06:41 PM
  #2233
F N CUDA's Avatar
Never gonna happen, the XX4 will blow away the XXX4 on a real offroad (rough) track and still hold it's own on a smooth track.
There are several good setups for the XXX4 in this thread tho.
The kit setup is close and only needs a couple variations to go fast.
Start there and tweek it to do what your driving style needs.
F N CUDA is offline
Old 11-04-2008, 07:38 PM
  #2234
Super Moderator
I think losi makes more than one body for it.
Old 11-05-2008, 06:03 PM
  #2235
NOFX's Avatar
Thanks for that, i love my xx4, in Australia we've been runing 13.5 as our stock class and the car has been awesome, but we've just aligned ourselves with the USA and 17.5 has become the stock motor (which i dont mind, i also think that the usa has it right with the 13.5 being the superstock motor but here its 10.5 and therefore i might as well be running mod) anyway the xx4 is getting eaten in a straight line with the 17.5, and you can get much more cooling into a xxx4 so they can be geared taller and the much more efficient drive train means i have to go xxx4, i'll look through the setups in here and see what the standard one is and go from there, im preparing for our nationals which are being held in mid summer on a 1/8th sized track with big jumps everywhere and a mix of high speed corners and tight ones, reasonable grip but dusty and blockheads/x2000's as the control tyre
NOFX is offline
