Losi xxx-4
Old 08-20-2008, 08:53 PM
  #2161
Nitronut3's Avatar
I have my XXX-4 for sale in the FS forum.
It has ALL Alumnium pivots and even the ALumnium castor blocks.
PM Me for pictures.
$110 shipped.
Nitronut3 is offline
Old 08-20-2008, 09:09 PM
  #2162
Briguy's Avatar
Trader Rating: 125 (100%+)
nitronut3 , YGPM .
Briguy is offline
Old 08-21-2008, 05:26 PM
  #2163
chedda bob's Avatar
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 149 (100%+)
didn't get any front pivots finished today, but did snap a pic of the caster blocks installed..... so here it is
chedda bob is offline
Old 08-21-2008, 07:27 PM
  #2164
BuggyKing's Avatar
Trader Rating: 17 (100%+)
those r nice. Were u having issues breaking them.
BuggyKing is offline
Old 08-22-2008, 08:28 AM
  #2165
jag5508's Avatar
Trader Rating: 15 (100%+)
What are you guys using for a battery hold down on lipos stock one doesn't seem to fit over the orion packs ?
jag5508 is offline
Old 08-22-2008, 09:22 AM
  #2166
F N CUDA's Avatar
Trader Rating: 34 (100%+)
I use the stock battery hold down.
Tape the battery to it and use longer screws on the posts to lift them up a little and I've been good to go.
I've seen velcro and zipties too, I use electrical tape on the ends and in the middle.
F N CUDA is offline
Old 08-22-2008, 10:37 AM
  #2167
BuggyKing's Avatar
I just used 4 zip ties and tied it to battery my Orion 3600. Works great.
Old 08-22-2008, 04:27 PM
  #2168
nitrotruckn's Avatar
I'm using the venom 5000mah lipo pack and the only modification required was to dremel the ribs out of the battery tray. After this is done, there should be no need to raise the hold down posts. Fits great
nitrotruckn is offline
Old 08-22-2008, 04:33 PM
  #2169
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
This is the route I took and it seems to be working good also.
yzracer758 is offline
Old 08-22-2008, 05:44 PM
  #2170
jag5508's Avatar
Thanks for the help guys
Are you guys using the stock setup with lipos?
really need a good setup for next week all the guys at track I run at run B44's and want to smoke em with my losi
they think it can't compete with them so I took it out of the closet haven't ran it for a couple years the shocks still feel better than any of theirs.
jag5508 is offline
Old 08-22-2008, 05:57 PM
  #2171
JeromeK99's Avatar
Your XXX-4 should be fine.. We have several of us running them at our track and just about every other 4wd you can think of!
Just because it's older, doesn't mean it's crap.. just older.. lol
Nothing better in a race than hearing a B44 or ZX-5 grinding up their beveled gears or spurs! We get one of those guys every week! The XXX-4 guys aren't just breaking down.. usually it's a hard crash or something to take us out.
Have fun!
Jerome
JeromeK99 is offline
Old 08-22-2008, 06:25 PM
  #2172
jag5508's Avatar
Got that right no bj4 b44 or what ever they are calling them these days can take beating I put on my G+ a couple years ago.
I just don't know if the stock set up is good for lipo or where to add the weight.
jag5508 is offline
Old 08-22-2008, 06:47 PM
  #2173
I'm running real close to the stock set up for now -
one .030 spacer under the caster and steering block ballstuds.
gray springs in front and yellows in the rear...
30w shock oil (f&R)
sway bar(rear)
10 degree hinge pin brace (front)
1 degree block(rear)
5oz. added weight on the battery side(difference between 3300nimh and the lipo)
slipper locked down
tires- vary with tracks
This is my current outdoor loamy track setup, however I constantly test and this could change.
Old 08-22-2008, 08:08 PM
  #2174
sport10's Avatar
You add weight to better balance the buggy. I would install the lipo and check the left to right balance and add weight to get it as close to balanced as possible. This will make it jump better. Most of the guys here are running a stick 4800-4900 lipo without any additional weight and doing well.
sport10 is offline
Old 08-22-2008, 08:41 PM
  #2175
jag5508's Avatar
Thanks guys sounds good
jag5508 is offline
