Like Tree1Likes
Losi xxx-4
Old 07-22-2008, 05:24 AM
  #2086
just wondering what rear wing some of you are running are you just using the standard one ? the track i race on has a very fast main straight/burm and i was thinking of trying some thing with a bit more downforce to keep the car planted at speed i notice that the B44 has a 6.5" wide wing on it has any one tried one of these.
dirt buggy is offline
Old 07-22-2008, 08:13 AM
  #2087
AE
I run the stock xxx4 wing w/ out a wicker bill. I tend to like a car that generates a lot of corner rotation and it might seem a tad loose to some, but I try to get the car to sit on the rear and gain traction that way. I would only try a wicker bill or more agressive wing if it was really loose. Just my .02
Dyno Dan is offline
Old 07-22-2008, 05:50 PM
  #2088
morris's Avatar
Trader Rating: 44 (100%+)
i run my xxx4g+ with a one-way in the front and i got way to much steering.i swapped it out with a diff and it pushed.my problem with the car is that under acceleration it like driving a car that has no tration what so ever...its all over the place...lol
morris is offline
Old 07-22-2008, 06:00 PM
  #2089
would you mind posting your setup so we can help diagnose your problem?
DanGriffin is offline
Old 07-24-2008, 05:38 PM
  #2090
BuggyKing's Avatar
Trader Rating: 17 (100%+)
do u guys run 3 degrees of squat in the rear.
BuggyKing is offline
Old 07-24-2008, 11:00 PM
  #2091
AE
I run 3 degrees anti squat in the rear.
Dyno Dan is offline
Old 07-25-2008, 05:15 PM
  #2092
hi just wondering if any one could tell me what sort of track ie surface etc you would use the losi BK BAR tires on and what advantages or disavantages they may have.Also what front tire would you run with these a taper pin?
i know it depends on a lot of other factors but just thought i would ask your opinions
Old 07-25-2008, 08:40 PM
  #2093
jrr102486's Avatar
we were using them on a drier indoor dirt track. normally we run slicks but, for some reason the track was drier than normal and the bk bars worked well.
jrr102486 is offline
Old 08-02-2008, 04:25 PM
  #2094
BuggyKing's Avatar
having issues with slipper. I tightened it as much as I can and still is slipping. Any info on this. It slips bad on full throttle. thx guys,
Matt
Old 08-03-2008, 01:21 AM
  #2095
the pucks on your slipper may be worn and need replacing .
i was having similar problems with mine even after replacing them etc the slipper would always need some adjusting during a race meeting so in the end i glued mine up so its solid since then it has not given me any more problems i have done 5 race meetings and 5 practise days with this set up and so far the diffs have not given me any problems i did pull the diffs down after the 3 meeting just to grease them but that was all .
Old 08-03-2008, 08:31 AM
  #2096
BuggyKing's Avatar
dirt buggy,
Hi the pucks r brand new. The spur has a bit of wobble to it when I put them in. Dont know if this is causing the slipper to slip even though the nut if full locked. thx
Old 08-03-2008, 09:01 AM
  #2097
my spur wobbled side to side as well, i have the kevlar gear, maybe when you put your pucks in your fingers had oil or something on them, or the slipper discs (metal parts) are badly glazed.
Tater salad is offline
Old 08-03-2008, 09:41 AM
  #2098
BuggyKing's Avatar
tater salad,
It is a brand new slipper assembly. New Spur, slipper hubs, pucks, top shaft bearings and pulley gear. Strange.
Old 08-03-2008, 11:24 AM
  #2099
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Matt, keep tightening it til it stops slippin, run it, tighten over and over.
Make sure the nut isn't slippin loose after you set it, mark it so you know it is stayin put.
They talked about it in this thread.
Watch out dude, I'm back
F N CUDA is offline
Old 08-03-2008, 01:15 PM
  #2100
JeromeK99's Avatar
It only takes one run to toast your slipper pads in the XXX-4.... If you ran a few laps with this problem you might have glazed them.. once that happens you just have to replace them...
Jerome
JeromeK99 is offline
