Losi xxx-4
Old 05-31-2008, 11:01 AM
  #1966
d16dcoe45's Avatar
Originally Posted by jrr102486
i used it in the front for a while. it was a good diff but the one way imo is a better choice if your looking for something for the front. the rear is still holding its own very well
I always run the one-way in the front. That is pretty much a given if you want the xxx4 to steer. I was just curious about using the cr in the rear.
I can't seem to find the steel xxx4 rear outdrives anywhere so I am going to run the plastic xxx4 outdrives (with savers) in the rear of the cr.
Anyone ever run the (d-shaped diff ring style) plastic outdrives in the rear of an xxx4 or xxx cr?
d16dcoe45 is offline
Old 06-03-2008, 05:32 PM
  #1967
Nitronut3's Avatar
Team Losi Racing xxx-4g+ for the win
Nitronut3 is offline
Old 06-03-2008, 06:40 PM
  #1968
d16dcoe45's Avatar
My xxx4g is super dialed. I am so glad I never sold this thing. Its so much easier to drive compared to my 501 or bj4. For those who need steering: doing the bellcrank mod (moving the ballstud over on the steering link) and running the 5 degree front pivot support totally changed the steering--it turns almost as hard as my 501 (which has more steering than any 4wd car I have ever tried). Totally my 4wd of choice.
I tried the dogbones in the rear and I am not totally sold on them yet, I am going to give it another couple of track days on them. They seem to slow the accleration down a lot compared to the alloy cvds, also they seem to slow the steering response--although I am noticing the car is a bit easier to drive with a bit more side bite.
Old 06-08-2008, 01:25 AM
  #1969
Default Removing roll pin from front axle hex adaptor
Anyone have a suggestion for a quick/easy way to remove the roll pin that holds the front hex hub onto the axle? Tried to poke it out with a hex driver tip end but it looks like it will need more force as it's pretty well stuck in place.
Never been a fan of roll pins for this reason... hard to insert and even harder to remove
Focus is offline
Old 06-08-2008, 04:09 AM
  #1970
Trader Rating: 14 (89%+)
You have more than likely now rolled the edges making it a lot more difficult to remove either way. Your best bet (not easy but there is no easy if you want it done properly and not damaged) is to get another person, unless you have more than two hands, a vice, a pin punch the same diameter as the pin and a ball pein hammer. If none of these is available use a press and if thats not available butcher the thing until it comes out and replace all the parts you have damaged in the process
autoset is offline
Old 06-08-2008, 04:53 AM
  #1971
hobbipro's Avatar
Trader Rating: 23 (100%+)
I've had to use a small nail and lightly tap those pins out before, or atleast get it out enough to get some needle nose pliers on it. Either way have a new pin ready they are usually trashed after removal.
hobbipro is offline
Old 06-08-2008, 05:35 AM
  #1972
Thanks for the tips
Sometime in the future might consider replacing the roll pins with made up pins if I can find the right diameter spring steel to cut down to length.
Focus is offline
Old 06-08-2008, 05:45 AM
  #1973
macr0w's Avatar
I just pulled my Sphere comp esc out to be sent back to LRP for repair.
I think I going to put my Mamba Max in my XXX4G+ and see how it goes.
Now comes my question(to which I think I know the answer): Can I run an Orion Vortex 5.5 motor with a Mamba Max? Can't I just leave off the sensor wire run it like that?
I know you can't run a sensored esc on a non-sensored motor. But can't you run the opposite with no problems? I have never done it but I think I read that you can.
macr0w is offline
Old 06-08-2008, 10:12 AM
  #1974
hobbipro's Avatar
Yes, you can run sensored motors on the Mamba max with the newest firmware. You may have to adjust the motor timing on the Mamba software but otherwise should work fine. You may notice a strange noise when it first starts to roll, but it wont hurt the motor. Leave the sensore wire off.
hobbipro is offline
Old 06-08-2008, 10:20 PM
  #1975
F N CUDA's Avatar
Trader Rating: 34 (100%+)
If the pin isn't broken off completely you can get a good grip on it with some wire cutters/dikes/dykes you know and pry it out.
If it's broken off, punch it out with a new pin halfway and then pull them both back out with the wire cutters.
F N CUDA is offline
Old 06-09-2008, 12:59 AM
  #1976
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Having a few dramas with the one I installed. The right hand bearing's seem to come out of the race for no reason, I've replaced it twice..... Any idea's on the problem? has any one else had this problem?
dirtdustingdavo is offline
Old 06-12-2008, 04:06 PM
  #1977
kuzo's Avatar
Default I must be an idiot
OK, I cannot keep this slipper tightened. I got one used and the slipper is constantly loosening after I disassembled to add in ceramic bearings. I realized at first (I mean after I destroyed the belt from binding ) I did not put sufficient spacers in on top of the bearing and the nut itself was rubbing the idler pulley metal thingy. Replaced the belt and now have to rubbing happening but the nut keeps working loose after a few minutes of running eventually not moving at all.
I rebuilt with what I am pretty sure is a new wavy washer thing but still having a problem. I'm running a Novak 5.5 in it with a 18 tooth pinion. Pinion is as bit high but it does run cool enough.
Where should I start? I've never had these problems with XXXT and T4 trucks. The 4WD thing is a bit new to me and ajusting the slipper on this thing is not a quick process like 2WD models. Thanks for any advice you can give.
kuzo is offline
Old 06-12-2008, 04:35 PM
  #1978
Nitronut3's Avatar
will CR buggy rims have the right offset for my XXX-4.
I need a new set and all my LHS has is CR Rims.
If its anything, im running a CR suspension on the xxx-4
Nate
Old 06-12-2008, 04:49 PM
  #1979
Team Tekin
yzracer758's Avatar
Nate
Are you talking about front or rears? Rears are the same, but the fronts are different.
yzracer758 is offline
Old 06-12-2008, 05:04 PM
  #1980
macr0w's Avatar
Should I advance or retard the timing? What causes that and how would I know which way to go? What effects should I be looking for?
macr0w is offline
