Like Tree1Likes
Losi xxx-4
Old 05-06-2008, 08:27 AM
  #1906
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
anyone tried using a spool up front??
Marcos.J is offline
Old 05-06-2008, 08:34 AM
  #1907
sport10's Avatar
I wouldn't think a front spool would be good for dirt. Isn't a front spool suppose to tone down the steering which would not be a good idea for the XXX-4 which seems to already hurt for steering box stock. That is why so many go to a oneway. For more steering.
sport10 is offline
Old 05-06-2008, 09:01 AM
  #1908
Super Moderator
Marcos.J's Avatar
thats what i thought
Marcos.J is offline
Old 05-06-2008, 09:18 AM
  #1909
macnkitty2002's Avatar
What weight shock oil will be a good base setup for my XXX-4? I have green front springs, and red rear springs. Red, three hole pistons. I run on a tight, technical track with a few small whoops but nothing major (built as a 1/10 track, not 1/8). I first tried 40/35 but that seemed too stiff. What should I try to get a more plush ride?
Also, does anybody run a rear swaybar? I got the tuned swaybar set and put on the thinnest one but that seemed to numb the rear suspension.
macnkitty2002 is offline
Old 05-07-2008, 01:18 PM
  #1910
Does anyone one got any pics of the xfactory oneway for the xxx-4 ?There site gives you no info and no pic's on that product .God that site suck's !when it comes to getting any info.Hopefully there products and custmer support are better .bert
russo11218 is offline
Old 05-07-2008, 02:02 PM
  #1911
just got my first xxx4 off ebay for $150 and will race it at the local track. what wheels will fit on the proline holeshot tires, not sure if the proline wheels will work need some help.
tigerboy is offline
Old 05-07-2008, 04:06 PM
  #1912
sport10's Avatar
I would run 30 in the front and 27.5 in the rear. Also, go to either pink or yellow springs in the rear. Unless the track is bluegroove with high traction you will probably want to leave the rear swaybar off.
sport10 is offline
Old 05-07-2008, 04:20 PM
  #1913
sport10's Avatar
One the Lesro Oneway subject there use to be pics of it when it first came out. I can not find them now. I can say it has a nicely machined aluminum housing that is annodized blue and some nice aluminum outdrives too. The oneway bearings are larger than the losi version and last much longer. I have been very happy with mine and have no doubt you will too.
sport10 is offline
Old 05-07-2008, 06:21 PM
  #1914
Super Moderator
Marcos.J's Avatar
any losi 2.2 wheel
Marcos.J is offline
Old 05-07-2008, 06:26 PM
  #1915
R/C Tech Elite Member
losi guy's Avatar
Trader Rating: 38 (100%+)
If you haven't got a front one-way put one in it will give the car a lot more steering.
losi guy is offline
Old 05-07-2008, 10:04 PM
  #1916
Nik
Nik's Avatar
is it common practice not to run a servo saver? Ive seen some people run the stock unit, and some people using other setups or even an aluminum arm.
since i don't have the stock unit I was thinking of getting a kimbrough one or just using the stock plastic arm used on the 8ight. Or is it really worth it to pay the 12 bucks to get the stock one?
Nik is offline
Old 05-08-2008, 01:49 PM
  #1917
biggins's Avatar
i use the servo arm from the buggy or truck i shave off a little of the plastic from the side the lock-nut would normally go on and then that is were the ball stud will go thats all i did, made the car a little more responsive.
biggins is offline
Old 05-08-2008, 04:36 PM
  #1918
Matt Howard's Avatar
So I'm putting my new xxx-4 together tonight and Losi has started to include the LCD's, yellow HD belt, and VLA rear arms/hubs now in the kits. Now i've got extra LCD's and a HD belt kit since I ordered them along with my kit
Matt Howard is offline
Old 05-08-2008, 08:07 PM
  #1919
It also has the rebuildable universals off of the xxx-CR in the rear instead of the aluminum CVD's
Old 05-09-2008, 07:46 AM
  #1920
hobbipro's Avatar
Trader Rating: 23 (100%+)
Thanks Matt, more parts to buy now I really do love how Losi and Associated make running upgrades to there current models.
hobbipro is offline
