Losi xxx-4
Old 04-08-2008, 08:48 PM
  #1756
schmelme's Avatar
The xxx4 can be kinda noisy. Run the belt loose enough so it rachets 1-2 times under the hardest braking you can do.
schmelme is offline
Old 04-08-2008, 10:19 PM
  #1757
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Default b
ok, I am going to pick up the g+ HD belt, it is kinda whiny too, I am running the blue spur and a 18 pinion I believe...
trdsupra88 is offline
Old 04-09-2008, 08:40 AM
  #1758
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Crazy Carl
Jerry pack the oneway with black associated grease.
And grind the pins on the cvds so they slide in and out of the out drives with the alum. ring on it
This will save you or extend the life of the 1 way
Thanks Carl. I'm building the oneway today so it's good that you gave me that info.
Jerry P is offline
Old 04-09-2008, 08:56 PM
  #1759
Trader Rating: 23 (93%+)
does any one know if they ever had front steel outdrives on the xxx4
afish is offline
Old 04-10-2008, 08:06 AM
  #1760
jrr102486's Avatar
not that i can remember, buti took the xxx-cr outdrives and put them in mine. they work great!
jrr102486 is offline
Old 04-10-2008, 02:36 PM
  #1761
d16dcoe45's Avatar
You can get an extra set of the steel rear xxx4 outdrives and put them in the front (exactly the same) or get the xxxcr outdrives.
I would keep the plastic, its alot lighter--mine seem to be pretty durable, no problems yet.
d16dcoe45 is offline
Old 04-10-2008, 06:49 PM
  #1762
biggins's Avatar
im actually running a front one-way with plastic diff in the rear works really great
biggins is offline
Old 04-10-2008, 10:12 PM
  #1763
jrr102486's Avatar
rite now im running the one way in mine as well but keep the other one built just in case something happens.
Old 04-10-2008, 10:49 PM
  #1764
where is a good place to get a oneway at
afish is offline
Old 04-10-2008, 11:12 PM
  #1765
SMcpot's Avatar
Trader Rating: 22 (100%+)
X-Factory sells a pretty robust English-made oneway. But if you're looking for something less expensive, I've got a brand new, never-used Losi oneway unit for $35 shipped.
SMcpot is offline
Old 04-11-2008, 08:01 AM
  #1766
how much do they help
afish is offline
Old 04-11-2008, 08:07 AM
  #1767
jrr102486's Avatar
ive noticed a lot more on power steering. also takes hairpins a lot better. take the one way and the cr steering rack thru the chassis ans the thing turns on a dime!
Old 04-11-2008, 10:01 AM
  #1768
biggins's Avatar
anybody have the steering rack mod pics avail?
biggins is offline
Old 04-11-2008, 10:30 AM
  #1769
jrr102486's Avatar
here are some pics. ive raced wih this guy and his is just dialed
http://www.rctech.net/forum/showpost...postcount=1577
hope this helps
Old 04-11-2008, 02:04 PM
  #1770
Ive just got a xxx4 G+ from my bro, and cant get it to steer correctly. We went over the whole car, DLed setups, but cant find anything to make it steer better. At high speeds it turns fine, but through corners you have to take it very slow and wide. Any suggestions or similar things going on with your xxx?
browndja is offline
