Losi xxx-4
Old 03-25-2008, 08:35 PM
  #1726
Ansel's Avatar
Default LCD
I tried the LCD's on my XXX-4. I practiced four packs & in the first qualifier one LCD broke. I had no replacement so I bumbed a steel one from a buddy.
In the third qualifier the other one exploded so I'm not a fan of LCD'S.
I guess my 13 turn Revolution was too much for them LOL.
Ansel is offline
Old 03-26-2008, 08:38 AM
  #1727
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Here is something you can try for steering I use it and it is great
I used the front alum. caster blocks from the bj4 and the hinge pin from a b4 and some alum. spacers from kyosho ( these can be from anything, just happened to have these)
I used set screws to capture the pin. And the spacers allow you to move the caster block forward or back. I have it forward 1mm
Also use the xxxcr rear with stock bones
No cutting, everything fit great. May need to sand a c*** hair off a spacer if they are tight
Crazy Carl is offline
Old 03-26-2008, 08:49 AM
  #1728
d16dcoe45's Avatar
Carl, when you say "CR rear with stock bones" you mean the CR thrust and diff assembly with the stock XXX4 alloy CVDs?
How about spring choice for LIR? I am at silver front and pink rear and steering is surprisingly good.
d16dcoe45 is offline
Old 03-26-2008, 08:55 AM
  #1729
Crazy Carl's Avatar
Yes to the cr diff assembly and no to the cvds
I use stock cr bones
Old 03-26-2008, 08:58 AM
  #1730
Crazy Carl's Avatar
Sorry I forgot the springs yellow rear and orange front
I may try the silver but it may make my s\t a little twichy depends on the track and the day
Also run 1 deg rear kickup (or pro squat)
Old 03-26-2008, 10:29 AM
  #1731
d16dcoe45's Avatar
Another question: can you use the xxx cr plastic rear hubs--with the vertical ball studs? Does it change the rear offset at all? I want to be able to adjust roll-center in the rear, can't do it with the stock hubs or inner camber link mounts.
Old 03-26-2008, 10:56 AM
  #1732
Trader Rating: 23 (93%+)
please post some pics of that i would like to see that
afish is offline
Old 03-30-2008, 05:30 PM
  #1733
I love running my xxx4, but every time I race it the rear end comes apart. It seems that the whole rear end is held on up 4 screws with the 2 going into the transmission cover being the most important. How can I keep my screws from stripping out during races and requiring a complete rebuild?
Thanks!
SeanF is offline
Old 03-30-2008, 07:31 PM
  #1734
macnkitty2002's Avatar
Put some Shoo-Goo on your screws.
macnkitty2002 is online now
Old 03-30-2008, 07:53 PM
  #1735
Someone also suggested to use CA, is this a bad idea?
SeanF is offline
Old 03-30-2008, 08:05 PM
  #1736
new to the xxx4 like the car broke the chassis first weekend out does any one have pic of the steering mod is it the same mod that can be done on the mf2
losiboy is offline
Old 03-31-2008, 12:37 AM
  #1737
i broke my chassis first weekend also and bent a rear shaft bad and a front diff cover and a tie rod and the front out drive. not to cool.
afish is offline
Old 03-31-2008, 10:54 AM
  #1738
Shoo-Goo does not crack like CA will sometimes.
Old 03-31-2008, 01:11 PM
  #1739
HuntersDad's Avatar
Trader Rating: 43 (94%+)
Originally Posted by Kevin Grant
Hey everyone I was racing a couple of weeks ago and and I did a wonderful cartwell down the strat away and in doing so I broke the chassis and front cover were the belt goes. so in short I am looking for a chassis and front belt cover for my buggy if any one has anything to help me out please pm me
You guys need to do the front end mods. I just dont break anymore.
HuntersDad is offline
Old 03-31-2008, 07:13 PM
  #1740
new to the xxx4 what is the front end mod
losiboy is offline
