Losi xxx-4
Old 03-01-2008, 09:58 PM
  #1666
Trader Rating: 23 (93%+)
ive got a problem with my xxx4. i raced it today and going down the straightaway the backend would pop up and flip over end ways kinda weird. what should i do. it was hard to drive because if u got on the brakes hard thatback end came up and over fast.
afish is offline
Old 03-02-2008, 06:49 AM
  #1667
Alltapdout's Avatar
Wow. I would add some spring in the front or take some out of the rear. Maybe change your front tires?... Or, just slow down a little easier.
Move your battery pack to the rear position may also help if its not there.
Alltapdout is offline
Old 03-02-2008, 08:22 AM
  #1668
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Is this a new problem? Have you raced this track before?
If you run a oneway front diff is it locked up?
F N CUDA is offline
Old 03-02-2008, 09:29 AM
  #1669
yes first time onthe track and the car. i could see the rear going left or right but coming all the way over the front is messed up. i did some searching and did find some people that had the same problem.
afish is offline
Old 03-02-2008, 09:42 AM
  #1670
Registered User
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
afish ygpm
Dasupacat1 is offline
Old 03-03-2008, 12:35 PM
  #1671
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
TrakPower 4900mAh LIPOS ARE NOW ROAR APPROVED. GOLD BARS ARE GOING TO BE EVERYWHERE.
http://www.BulldawgRC.com
Bulldawg RC is offline
Old 03-03-2008, 06:27 PM
  #1672
biggins's Avatar
just getting back into rc after a 1.5 year layoff caused by my baby boy i got my original xxx4 back i just wanted to know if there are any tricks to do and what rear arm and hub combo are people using i was thinking of putting the cr stuff on anything different with the steering anybody trying to mod the cr rack in? please help i am no rookie been racing for about 18 years just out of the 4wd game for about 2 years
biggins is offline
Old 03-03-2008, 06:33 PM
  #1673
bk2 arms and hubs. You could run cr hubs which allow vertical adjustment. 3 washers is the same height of the bk2 hub.
Some guys are running a rack..a piece of carbon or metal that is the outline of the cr rack but with the ballstud vertical not horizontal. It's a little involved getting on and, without even more work, it gets rid of the sealed drivetrain idea...
DanGriffin is offline
Old 03-04-2008, 02:56 PM
  #1674
biggins's Avatar
thanks dan got a setup to help me out for mcculloughs email me thru the mcculloughs forum thanks
bob higgins
biggins is offline
Old 03-05-2008, 11:23 AM
  #1675
SMcpot's Avatar
Trader Rating: 22 (100%+)
Questions??
Does boiling even the graphite composite parts make them more flexible? And has anyone that has boiled the standard plastic chassis and diff covers had any breakage?
SMcpot is offline
Old 03-05-2008, 12:24 PM
  #1676
macnkitty2002's Avatar
You don't want to boil graphite parts, because the purpose of them is to replace soft parts with stiffer ones.
macnkitty2002 is offline
Old 03-05-2008, 12:33 PM
  #1677
SMcpot's Avatar
Right, but in case the plastic parts aren't offered anymore, like the chassis and diff covers, and you want something that isn't as brittle as graphite, will they become more flexible after boiling....
SMcpot is offline
Old 03-05-2008, 04:40 PM
  #1678
I guess the plastic material that is in them would soften up a bit.
Old 03-05-2008, 08:55 PM
  #1679
any one have problems breaking front diff covers. i have broke 2 of them in one weekend. any fixes to this besides better driving.
afish is offline
Old 03-06-2008, 04:40 AM
  #1680
Alltapdout's Avatar
Make sure you have the correct screws securing it properly.
