Losi xxx-4
Old 02-27-2008, 03:45 PM
  #1651
macnkitty2002's Avatar
what weight shock is oil a good basic setup for the XXX-4? I am using 3 hole pistons with green springs in the front and red springs in the back.
macnkitty2002 is offline
Old 02-27-2008, 04:27 PM
  #1652
Alltapdout's Avatar
It would depend on the conditions you are running. I've changed my oil to 40 weight. But I run at a primarily 1/8 scale track, or in the back yard. ... When the grass gets cut
Alltapdout is offline
Old 02-27-2008, 05:04 PM
  #1653
Yes I will be running on a 1/8 track, but there are few jumps and are small at that. I will give 40 all around a try. Thanks
Old 02-27-2008, 06:24 PM
  #1654
Travis Amezcua's setup is a great starting point almost anywhere..
http://losi.com/Products/Support.aspx?ProdID=LOSA0015
DanGriffin is offline
Old 02-27-2008, 08:31 PM
  #1655
Trader Rating: 23 (93%+)
im running the sidewinder 5700 combo in my xxx4 and its nice cant beat the value of that combo. but parts to stock up on are diff covers and arms.
afish is offline
Old 02-27-2008, 08:33 PM
  #1656
i ran my car tonight. but had trouble keeping the lipo in the car it kept coming out of the car. i ran the orion 32 and the36oo what are u guys doing to hold them in?
afish is offline
Old 02-28-2008, 08:38 AM
  #1657
strapping tape.
Old 02-28-2008, 09:16 AM
  #1658
jrr102486's Avatar
ive really never had a problem. i velcro my body to my chassis and make sure my 6000 is tight in the battery slot. it works for me.
jrr102486 is offline
Old 02-28-2008, 09:17 AM
  #1659
can't you flip the battery strap upside down so that it is flat on a Lipo pack?
Old 02-28-2008, 11:05 AM
  #1660
i have to flip the strap but it comes out the side. so i used some zip ties
afish is offline
Old 02-28-2008, 04:07 PM
  #1661
Alltapdout's Avatar
Try squeezing a small piece of foam in front of that battery to keep it tight.
I would have included a picture, but it seems that I cannot add attachments for some reason. Maybe next time.
Old 02-29-2008, 08:35 PM
  #1662
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Flip the battery strap flat side down and tape the battery to the battery strap in two spots.
Works great. You can take the battery out easily with the strap.
F N CUDA is offline
Old 03-01-2008, 12:25 PM
  #1663
Unoversace's Avatar
I grinded down the bumps that are there for the NIMH's and my lipos fit perfect. They were falling out before, now not one has slipped out.
Unoversace is offline
Old 03-01-2008, 05:28 PM
  #1664
i tested out my car today. the 19 turn provides enough power for me right now, it seems to be geared pretty well with a 27 tooth pinion. i have 40 weight oil all around, with three hole pistons, green springs front and reds in the rear. installed a rear swaybar and rebuilt the diffs, which were tight as balls when i got the car. there were actually grooves where the diff balls rolled. i will need to play around with the diff settings as i am not used to the car yet, but right now i can already tell they need to be tightened. i have a standard spektrum servo in it right now, slow as hell but it turns the tires. i have what looks like step pins on it now, which is good for bashing but probably no good for track use. what do you all recommend for a good all around track tire?
Old 03-01-2008, 05:51 PM
  #1665
Unoversace's Avatar
My local track is hard packed mud. Very high grip and fast. I run losi pink taper pins, ground down. They work great at that track. I don't use the car for bashing at all so I can't help you there.
