Losi xxx-4
Old 02-07-2008, 03:34 PM
  #1636
jasburrito's Avatar
I found the friction from the slipper net being so loose it was hitting the tension bar.
jasburrito is offline
Old 02-07-2008, 07:29 PM
  #1637
Alltapdout's Avatar
That'll do it.
I run no extra weight in my buggy, fly's fine.
Alltapdout is offline
Old 02-07-2008, 07:32 PM
  #1638
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Crazy Carl
Who pulled your string
I believe this a Losi xxx4 forum not a kyo--slow forum
sorry I thought I stumbled into the 4wd of the week forum
MikeXray is offline
Old 02-08-2008, 08:23 AM
  #1639
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Do I detect a hint of sarcasm? or envy
Crazy Carl is offline
Old 02-08-2008, 08:51 AM
  #1640
MikeXray's Avatar
machines I can buy, skills I have to learn, sadly the latter is the harder of the two.
MikeXray is offline
Old 02-08-2008, 09:04 AM
  #1641
MikeXray's Avatar
MikeXray is offline
Old 02-08-2008, 09:11 AM
  #1642
MikeXray's Avatar
Stupid forum... sorry for the 3x posts..
MikeXray is offline
Old 02-22-2008, 08:29 PM
  #1643
macnkitty2002's Avatar
is there any chance that the xxx-4 will be discontinued soon? i may be getting a used one soon, and want to know if i should hold out. will there still be continued parts support? i just want to bash and occasionally club race so i don't need a 1st class platform. will the xxx-4 suit my needs?
thanks!
macnkitty2002 is offline
Old 02-22-2008, 10:34 PM
  #1644
No, you will be completely fine. I have not heard anything of that nature, and don't believe to do so for some time. Remember, as is such the nature for any new product release from any company, even if it were announced now (a new 4wd kit for instance), it wouldn't be available at retailers for several months or more far beyond that.
I'm sure that many people on this thread would be far more than happy to help you with any questions that you have about the xxx-4. It's an excellent car! Have fun with it.
4wd Racer is offline
Old 02-23-2008, 08:29 AM
  #1645
Cool, thanks! Looks like I will be getting it then. $100 for a roller XXX-4 G+ with spare parts. Hopefully it has tires/wheels.
I have all the electronics, but I'm not sure if they will be appropriate for the car. I am probably using my Orion platinum Lipo with and LRP ESC. How much torque is required for such a car? I am assuming it is a light car, so probably not much torque is needed. Also, will a 19t motor be fine for bashing and general club racing (no motor requirements)? Or do I need something with more torque? Thanks in advance!
Old 02-24-2008, 12:25 PM
  #1646
I was told that the stock spur gear uses 48 pitch pinions. How big of a pinion gear should I use for a 19 turn motor? What about 14 turn? I don't want to go out and buy 20 pinion gears only to find out that most of them are not sensible to be using.
Old 02-24-2008, 10:05 PM
  #1647
Ansel's Avatar
Default Gear
I run around 6 to 8 teeth over the wind of the motor, this works for me.
If you use a 14 turn motor use a 20 to 22 pinon. for an 11 turn I would use an 18 or 19. If after 5 min your motor is real hot try a different gear. 120 to 160 degrees is not to bad if it's hotter it will burn up your brushes. If you have a temp gun take the temp at the endbell.
Ansel is offline
Old 02-25-2008, 06:40 AM
  #1648
Thanks, does this work with most RCs or just the XXX-4?
Old 02-26-2008, 07:53 PM
  #1649
Ansel's Avatar
Default Gear
Yes, I run arround 8 over in my XXX-T CR.
Get these upgrade parts they are awesome. They will make the front end much stronger.
http://www.rctech.net/forum/showthread.php?t=203016
Ansel is offline
Old 02-27-2008, 11:34 AM
  #1650
Trader Rating: 27 (100%+)
just recieved mu used xxx4 in the mail today hopefully running a sidewinder 5700 system with a orion 3600 lipo i cant wait to race electric again. what is the most common thing to break on the xxx4 so i can stock up
cheesecake is offline
