Losi xxx-4
Old 01-07-2008, 07:01 AM
  #1576
Briguy's Avatar
Trader Rating: 125 (100%+)
Anyone know if any other manufacture makes the aluminum pivot mounts ? I can find all but front 7.5 and front ,rear inner mounts . Mike Truhe said he thinks Losi is discontinuing because they cost too much to make . Also thought he heard someone else was gonna make them .
Briguy is offline
Old 01-07-2008, 04:10 PM
  #1577
schmelme's Avatar
Here are some crappy pics of the rack on my xxx4. I used the stock steering bellcranks and flipped them around so the long posts are down and towards the rear. Use the rear holes in the chassis for the steering posts. The cr rack is mounted to the holes using 4-40 bolts with low profile nuts on the bottom to lock to bolts from spinning as the rack turns.The rack is mounted so the the ends curve down in the front.(look at side view) If you want to you can drill out the hex mold in the cr rack and install the bushing kit used in the cr buggy. I didnt do this. You will need to grind the chassis accordingly but its not to bad(remove the front diff and pull belt aside unless your brave). I moved the servo back and drilled one set of holes and mounted a long tie rod as shown. The steering bellcrank can be reinforced like on truhes car but its good to have some give someplace. good luck
Attached Thumbnails Losi xxx-4-102_0719-medium-.jpg   Losi xxx-4-102_0720-small-.jpg   Losi xxx-4-102_0721-medium-.jpg
schmelme is offline
Old 01-08-2008, 07:54 PM
  #1578
ChrisWolfson's Avatar
Very nice looking Schmel...What are you accomplishing by running the CR rack on that car over the stock setup?
ChrisWolfson is offline
Old 01-09-2008, 08:11 AM
  #1579
Briguy's Avatar
I just bought a new G+ and looking at some set up sheets . the kit comes with new VLA rear arms and neither the kit`s set up or any other set shows that . There are more holes to choose far as shock and outer pin locations . Are you guys running the outer pin inside or out ? What about shock location on the arm ? Now that there are three choices instead of two .
Briguy is offline
Old 01-09-2008, 09:06 AM
  #1580
jrr102486's Avatar
i built mine to kit specs then went from there.
jrr102486 is offline
Old 01-09-2008, 09:27 AM
  #1581
Briguy's Avatar
Kit specs doesn`t show the new arms with different holes . Kit specs is for the older arms with just one outer hole and two shock holes .
Briguy is offline
Old 01-09-2008, 09:56 AM
  #1582
Default aluminum inner pivots??
Where can I find the front inner pivots in aluminum?
Norris
Norris is offline
Old 01-09-2008, 02:17 PM
  #1583
Briguy's Avatar
Norris
You can`t , Losi stopped making them along with front 7.5 .
Briguy is offline
Old 01-09-2008, 02:43 PM
  #1584
jrr102486's Avatar
true. i forgot that. ill take a look at it tonite when im down racing.
Old 01-11-2008, 07:11 PM
  #1585
nikos2002's Avatar
Trader Rating: 30 (100%+)
I'm getting back into racing with a XXX4 - it's been three years since I ran one - other than the CR steering rack - what other changes have I missed????
nikos2002 is offline
Old 01-12-2008, 05:38 AM
  #1586
Alltapdout's Avatar
Not a whole lot really, just some discontinuted parts .
Alltapdout is offline
Old 01-12-2008, 05:51 AM
  #1587
I just bought a new G+ and looking at some set up sheets.
xxx4/xxx4g+ - http://www.petitrc.com/view_news.php?id=4577
For others cars - http://www.petitrc.com/view_news.php?id=4622
Arn0 is offline
Old 01-12-2008, 09:32 PM
  #1588
jrr102486's Avatar
im putting mine in the inner most location. works good.
Old 01-13-2008, 06:09 PM
  #1589
junelopez's Avatar
IF it helps, I LOVE MY BUGGY. It has Balls...
junelopez is offline
Old 01-27-2008, 12:05 AM
  #1590
Trader Rating: 23 (93%+)
quick ? i got a new set of rear arms today #a9800 say xx4/xxx4 rear arms well it has the vla hole in it the 2 differnet holes for the carrier to go in to. are these the right arms or do u just use the inside hole.
afish is offline
