Losi xxx-4
Old 01-02-2008, 10:29 AM
  #1561
scott54's Avatar
Originally Posted by Drew Manzella
What is? The lack of active support for a 5 year old car?
Good luck. I accomplished it by going to a different car. My single biggest gripe about the XXX4 was the lack of steering and short of having a CNC mill at my disposal to re-engineer the steering linkage I was flat out of ideas.
The car is still very capable of hanging with anything out there, and yes, it can steer a lot. Run 57 pistons, red springs, and 27.5 oil in the front... Run shocks at 2-inside and camber in the second hole with two washers under the ballstud on the spindle carrier. This is what I was running... I'm changing everything up right now, if I get it better, I'll let you know. But that'll steer.
scott54 is offline
Old 01-02-2008, 11:11 AM
  #1562
Drew Manzella's Avatar
Trader Rating: 35 (100%+)
In ideal circumstances and everything is equal it is still a potent car - but that isn't reality.
A lot of people have simply gone to newer technology that works on a wider range of tracks.
Can you still win with one? Yes. Are there better cars out there now? Absolutely.
Now I'm not at all saying anything negative about you and your desire to continue running one. All I am saying is understand why people don't continue to run them.
I still have my XXX-4. I don't like it. Wanna buy it?
Drew Manzella is offline
Old 01-02-2008, 11:20 AM
  #1563
Damn double posts
Old 01-02-2008, 11:45 AM
  #1564
jrr102486's Avatar
where r u running the ball stud on the rack? stock? middle? far right? new setup?
thanx
jrr102486 is offline
Old 01-02-2008, 12:59 PM
  #1565
scott54's Avatar
thanx
I just run it in the stock position. Moving the ballstud may increase the steering throw but really has nothing to do with making the car's front end bite more when turning in.... that's just my opinioin, take it with a grain of salt.
scott54 is offline
Old 01-02-2008, 05:42 PM
  #1566
d16dcoe45's Avatar
I didn't read all the threads here and maybe this has been brought up before, but take a look a this pic--Its a XXX4 from the Worlds in Japan this past September. I think all the pros do something like this to get more steering out of their XXX4s. It looks like it requires a little trimming on the tunnel and a new alloy (or plastic) rack. Pretty neat stuff:
http://bp2.blogger.com/_uwoVC10q7eM/...G_7061blog.JPG
Its Mike Truhes car:
http://bp3.blogger.com/_uwoVC10q7eM/...G_7053blog.JPG
d16dcoe45 is offline
Old 01-02-2008, 05:53 PM
  #1567
d16dcoe45's Avatar
Ever since I got my BJ4 WE, I haven't really driven my XXX4. The BJ4 WE is amazing and makes you feel like you are an awesome driver (even if you aren't)--heroic is the word that comes to mind. Even so, I can't get rid of the xxx4--I absolutely LOVE the design, engineering and execution of this car (xxx4)--everything (design wise) feels "right" about it. Also, its a very fun car to drive--but its hard to get it to corner as hard as the Bj4. I don't personally think its a super fragile car (like most people do) but it definatley seems to break a bit easier than other 4wds. I would love to do the steering mod I posted above and see if I can get that hard cornering feel that makes the bj4 such a delight to drive.
On my small indoor, tight track (LIR) The BJ4 works great with diffs front and rear and I normally run the dual rate at about 95-97%. On the same track the XXX4 absolutely needs a one-way--and it still has trouble with some corners.
Old 01-02-2008, 10:25 PM
  #1568
Trader Rating: 23 (93%+)
any one know what parts to do that mod for the steering.
afish is offline
Old 01-02-2008, 10:54 PM
  #1569
F N CUDA's Avatar
Trader Rating: 34 (100%+)
That's the rack from the XXX CR buggy bolted to the XXX 4 posts.
F N CUDA is offline
Old 01-02-2008, 11:02 PM
  #1570
scott54's Avatar
thanx
Just got back from the track. I ended up putting Amezcua's setup on it from the Hot Rod Classic in 06. It's on the Losi website. THE CAR HAS TONS OF STEERING. I run on an indoor clay track with a lot of bite. That's the setup I'm going to run in Columbus at the CRCRC Midwest Champs next week.
scott54 is offline
Old 01-06-2008, 09:15 PM
  #1571
ChrisWolfson's Avatar
No doubt the XXX4 has steering. I haven't come across a situation where i couldn't get the amount of steering I needed. The new AE cars look pretty good, but the XXX4 is plenty competitive. It's nice to see the biggest mod class at CRCRC is 4wd this year. That's a departure from the norm. Between the Losi car, AE car, Academy car, Kyosho car, and Hot Bodies car there are so many good options. Makes for a fun class.
ChrisWolfson is offline
Old 01-06-2008, 09:25 PM
  #1572
jrr102486's Avatar
i put a one way in it now and it has a ton more steering, just need to dial it in to make it work to its full potential i just nee to put the outdrives into solidworks and have them machined out
Old 01-06-2008, 09:37 PM
  #1573
schmelme's Avatar
The xxx4 is dialed with a oneway but without it on tight tracks it lacks some steering. Besides the xxx4 oneways arent exactly bullet proof. I put a cr rack in my car and it turns as sharp as any car now. I 'll put up some pics its different than truhe's slightly. Takes about and hour and 5$
schmelme is offline
Old 01-07-2008, 01:45 AM
  #1574
yes please get some pics please
afish is offline
Old 01-07-2008, 05:36 AM
  #1575
Briguy's Avatar
Trader Rating: 125 (100%+)
I`m actually in the middle of building another one so please post pics when you can as I will set this one up that way .
Briguy is offline
