integy 16x5v6
integy 16x5v6
i just bought an integy 16x5v6 charger and was wondering what charging profie you mostly use, regular, fuzzy logic or booster. ill mainly be charging 3000hv's and 2400's
also is it ok to change the aligator leads to deans plugs to charge the batts.
Go with regular, always worked well for me. not sure about plugs.
to charge batteries with deans plugs, I just took a male connector and soldered about 1 inch of wire on to each lead and then cut of a little piece of plastic around the wire and just clipped the aligators to that
hope this helps
hope this helps
