Old 04-15-2008, 11:26 AM   #1
BCrumB4's Avatar
Questions?? B4 motor/speed control issue?
Hello, I'm running a B4 with a Novak GTB and 13.5 brushless and a spectrum receiver. My car is having a power pick-up problem.
The car will run fine on warm up laps but when I bring it to a complete stop to line up for a race when I go to take off the car wont go. I've changed the speed control to the Sphere Bush/Brushless and still the problem is there so I got a new brushless set up, and still. If I hold the car off the bench and pin it, nothing, once I roll the rear wheels it takes off with no in between and sounds if something is a miss with the trans. I have replaced everything in the rear-end, and still have the issue. Another new problem is that once the car is going I'll lose the binding on the receiver and all goes to fail safe. I can't even rebind it at this point. . All steering is completely fine at all times. Sometimes on acceleration the car will seem to miss a little, not sure if this is related. I have been very frustrated because this stuff isnt cheep so the car has been sitting for about a month, but I am in need of getting back on the track
Thanks for any help....
BCrumB4 is offline   Reply With Quote
Old 04-15-2008, 11:31 AM   #2
Trader Rating: 67 (100%+)
Since you changed everything else, it sounds like a problem with your radio and receiver. Is this an early Spektrum, newer DSM, or DSM 2? Have you fully reset the radio and receiver? Do you have a fail safe set incorrectly? Radio battery charge level is adequate?
nutz4rcyktw is offline   Reply With Quote
Old 04-15-2008, 12:47 PM   #3
BCrumB4's Avatar
I got the radio system in February 2008. It is the DX 3.0. I have tried to reset everything and go about putting it together like I had never had it before, and still nothing. I wasn't thinking it was the radio because I also have a Losi XX-4 and I have no issues with that car. I even took all electronic out of that and put them in the B4 with no luck. The battery pack I have in the car is fairly new, works fine in the XX-4 and the radio batters are new as well. I have heard something about some people having to "shield" their electronic.... Any word on what that might entail?
Old 04-15-2008, 01:01 PM   #4
beast95451's Avatar
Do you run the Spektrum radio system (radio & RX) on the XX-4 & the B4?
beast95451 is offline   Reply With Quote
Old 04-15-2008, 01:03 PM   #5
BCrumB4's Avatar
Yes i run the system in both cars. First thing I thought was that I hadn't changed the model number on the radio between the two, but I had so I ruled that out.
Old 04-15-2008, 01:07 PM   #6
beast95451's Avatar
Hmmm.
The XX-4 works fine, right?
And you put the XX-4 motor, esc, Rx, servo & battery in the B4?
Old 04-15-2008, 01:12 PM   #7
stick to 4wd. its faster anyway
RC collection is offline   Reply With Quote
Old 04-15-2008, 01:14 PM   #8
beast95451's Avatar
Thats helpful.....welcome
Old 04-15-2008, 01:16 PM   #9
You said you changed model numbers, do you have the radio parameters on the other model number set correctly?
Old 04-15-2008, 02:34 PM   #10
BCrumB4's Avatar
what I have done with the radio is go through and clear everything I've done and set it back to the factory settings on the two "models" (B4 and XX-4)
Not sure if that helps you, what do you mean by parameters? (expo, deadband.etc.)
Old 04-15-2008, 03:10 PM   #11
beez's Avatar
I have a similar problem with an MF2/GTB/13.5. I unhooked the motor from the car and noticed that it always refuses to start from a specific position (when the flat spot on the rotor is facing towards the rear of the car) so I eliminated the gearbox as the problem. Novak thinks it's my ESC, so I ordered a new one... If my problem persists as yours has, I'm going to rip my hair out.
I don't know if this is helpful, but maybe one more way to look at it.
beez is offline   Reply With Quote
Old 04-15-2008, 03:47 PM   #12
BCrumB4's Avatar
thanks beez, it's helpful to know that I'm not the only one have this type of issue. I'm going to give Novak a call next, just thought I'd see if anyone out here has found a fix...
Old 04-15-2008, 04:05 PM   #13
beez's Avatar
I've emailed steve Weiss at novak ([email protected]) a couple of different times and he always gets back to me very fast during business hours. Give him a shot, but if you're switched out your ESC and motor and it still persisted, I don't have any idea if he can help you or not.
Old 04-15-2008, 04:11 PM   #14
BCrumB4's Avatar
Great!! Thanks I'll give him a try.
Old 04-15-2008, 04:42 PM   #15
beast95451's Avatar
Originally Posted by beast95451 View Post
Hmmm.
motor/speed control D.Bates Electric Off-Road 1 09-06-2008 01:10 PM
Motor/Speed Control Issue? BCrumB4 Radio and Electronics 2 04-15-2008 12:51 PM
F/S Speed Control & Motor Vegasracer R/C Items: For Sale/Trade 0 02-02-2008 12:05 PM
Which brushless motor and speed control? pf100 Wisconsin & Illinois Racing 4 07-16-2007 12:12 AM
wtb speed control and 19t motor Hasee R/C Items: Wanted to Buy 8 09-02-2004 11:59 AM
