Old 04-14-2008, 07:06 PM   #1
Default RC10T4 with 10.5 brushless
What size pinion do I need to use with a 10.5 brushless motor? Is it the same as a 19t?
thanks,
Mike
Hillman is offline   Reply With Quote
Old 04-14-2008, 07:07 PM   #2
tschenck's Avatar
Trader Rating: 110 (100%+)
I run a 22t with mine. Not sure what a 19t calls for though.
tschenck is offline   Reply With Quote
Old 04-14-2008, 07:17 PM   #3
Trader Rating: 95 (99%+)
Last race I ran in 10.5 class I ran my Novak 10.5 with an 81 tooth spur gear and a 24 tooth pinion gear. Had plenty of power and did not get hot. This was on my T4 truck. Next run I may go up to a 25 tooth pinion and see what it does.
I was initially down around a 21 tooth pinion and it felt like a slug. On a recommendation of a fellow racer I went up in gear. It made the truck come alive both on the top end and bottom end.
The lower turn brushless motors seem to run a lot better if you gear them to the moon. Just keep an eye on the temps.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 04-14-2008, 07:38 PM   #4
I'm switching from a 19 turn motor to the novak 10.5 brushless. Right now I have the stock 87 tooth spur gear and a 19 tooth pinion. I'm just looking for a starting point for the brushless. I will be racing for the only the second time on Thursday.
Old 04-14-2008, 08:03 PM   #5
Carbonman's Avatar
Trader Rating: 30 (100%+)
Try a 24 tooth, it will be tight but it should fit. 10.5's like lots of gear...
Team Carbon
Need a little (carbon) FIBER in your diet???
Carbonman is offline   Reply With Quote
Old 04-14-2008, 08:52 PM   #6
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
The novak 13.5 and 10.5 do like a lot of gear. I would recommend something in the 24/25 78 or 81 area to start with. The Novak motors have a ton of torque and with the sintered rotor they can take the heat. My 13.5 has an issue with the braking causing it go get pretty warm. On average it gets 110 to 130 after a run and it hasent lost any performance.
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 04-15-2008, 05:53 AM   #7
Trader Rating: 40 (100%+)
I run 24/81 with my Trinity 10.5.....Dialed I've tried 25 didn't notice much difference on track but my motor was quite a bit hotter. This is going to vary track to track though. I run at Leisure Hours a very large high bite track.
jb7778 is offline   Reply With Quote
RC10T4 with lrp brushless system RCHobbyGuy R/C Items: For Sale/Trade 28 11-08-2008 01:38 AM
FS: New Factory Team RC10T4 w/brushless setup budfan08 R/C Items: For Sale/Trade 16 08-26-2008 04:02 PM
RC10T4 vehicle & Parts, Lipo Battery, Charger, brushless system, pinions etc for sale Cain R/C Items: For Sale/Trade 11 05-24-2008 11:43 AM
FT RC10T4 Brushless may trade for CRT.5 Pro reynolds716 R/C Items: For Sale/Trade 10 08-10-2007 08:00 PM
FS: Full race Rc10T4 with GTB4.5r Brushless Team Kamakaze11 R/C Items: For Sale/Trade 18 07-29-2006 01:21 PM
