Old 04-14-2008, 10:27 AM   #1
Team Tekin
Tekin Prez's Avatar
Default BL motors sensor plug damage
How much of an issue is the sensor plug or wires getting damaged on BL motors?
Tekin Prez
Tekin Prez is offline   Reply With Quote
Old 04-14-2008, 10:44 AM   #2
cfwdude's Avatar
If one of the wires is loose/missing, they make one hell of a nasty noise, and don't run well, if at all.
With the Novak non removable harness, if you can't repair it, you have to send it in for warranty repair work. Replacable harnesses would be nice.
Although, with 4 Novak systems over about 2 years, I've only had a loose sensor wire once, and never damaged the harness.
cfwdude is offline   Reply With Quote
Old 04-14-2008, 10:56 AM   #3
Trader Rating: 35 (100%+)
I have owned 3 GTBs over about 3 years, and never had a problem with the sensor wires or harness becoming damaged or coming loose.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 04-14-2008, 11:19 AM   #4
Trader Rating: 83 (100%+)
At our track we have had a few wires go bad on the Novak system. Basically what we have done is buy an LRP harness and cut and solder a new wire into the Novak plug. I would really like to see a plug like LRP and Speed Passion used IMHO. FYI itís the orange wire that seems to break. I know of one guy that bought the Deans micro 6pin connectors to help solve this problem.
Mark
B5M
Losi 22SCT
mrhenning11 is offline   Reply With Quote
Old 04-14-2008, 11:32 AM   #5
CCristo's Avatar
Trader Rating: 55 (100%+)
I've never had an issue with the harness on my Novak motors. I still prefer a plug though so I can use a different length harness in different applications. Having neat wiring with the long Novak sensor harness is sometimes impossible.
CCristo is offline   Reply With Quote
Old 04-14-2008, 11:36 AM   #6
Tech Legend
Wild Cherry's Avatar
I broken a few. (Torn wires) 1/10 off-road buggy
Just replace it, no "big" on the Lrp...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-14-2008, 11:39 AM   #7
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
A more secure connection would be nice, my 7.5 wire seems to come out too easily.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 04-14-2008, 11:45 AM   #8
badassrevo's Avatar
I have never damaged the harness or conector, but I have had it come loose.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 04-14-2008, 05:36 PM   #9
I have 2 years on both of my novak system and have had the plug come loose only one time, other than that no problems.
I do prefer the plugs on both ends, realy helps clean up the wiring.
Stallard is offline   Reply With Quote
Old 04-14-2008, 07:21 PM   #10
Trader Rating: 95 (99%+)
+1 for removable plugs on both ends of the connection. I've never had a plug come loose or get damaged.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 04-14-2008, 07:31 PM   #11
abailey21's Avatar
Trader Rating: 36 (100%+)
Jim,
Make it removable like everyone else
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-14-2008, 07:53 PM   #12
LRP style for sure. Being able to have diff length sensor wires is a HUGE plus.
I've only been running brushless about a month and had the sensoe wire come loose from the motor once. In the ZX5 with the motor being inline a "lawn dart" popped the wire out.
XXX-CR, XXX-T CR, XXX-SCT (Kertez conversion)
CRCRC.COM
Sneaky Pete Racing
Hammer Racing
Bike racer is offline   Reply With Quote
Old 04-16-2008, 08:21 PM   #13
Team Tekin
Tekin Prez's Avatar
It already has a plug. We were just deciding if it was worth the hassle of moving it to the top in the future or offering a shield.
I am surprised most esc's do not recognize a bad sensor and will run on 2. That is really hard on things... We do have the advantage of rolling to sensorless so you can finish the race without hardly noticing. If we loose a sensor or the plug entirely you might not even know it.
We also added a cool little feature for checking sensor operation. The top 3 leds light up relative to the sensors. You can roll the motor slowly and watch it happen in real time. Started as an engineering debug, but it was so cool we left it. Advantages of having an overkill microprocessor and 7 leds to play with.
Tekin Prez
Old 04-16-2008, 10:06 PM   #14
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
Tekin Prez
2+ years of being a loyal Novak BL system user and haven't had any issues, whatsoever, with the sensor wires or plug.
I also prefer removable sensor harness on both ends.
Tekin Prez
Looks impressive and after being shaken with the reliability of later editions of Novak GTBs that I read on the other thread, I'm keenly interested in your Tekin RS/RSPro BL systems. I plan to get one in the near future to try out.
Even with a USB plug to update the ESC firmware, please try to make your ESCs as water- and dust-proof as possible. I don't like ESCs where it's easy for dust and moisture/water to get inside the case like that of the Mamba (aside from my preference for sensored systems).
Hibernating...
Team Associated B4 * T4 * B44
Novak BL * Futaba TX/RX/Servos * Hyperion/Megapower Chargers
Orion/Yuntong/Maxamps Lipo * AMB #6655738
jobo_ph is offline   Reply With Quote
Old 04-17-2008, 05:15 AM   #15
abailey21's Avatar
Jim, when are you gonna send me your super secret sensor cable????
Attached to your super secret 8th system?
K.C.C.O.
Lipo and brushed motors? Damage? MOmo Radio and Electronics 4 01-28-2008 12:54 PM
Nomadio Sensor/transciever and sensor pack DaveH R/C Items: For Sale/Trade 14 05-14-2007 11:12 PM
Turbo plug Vs Standard plug mrhenning11 Electric Off-Road 1 04-16-2007 09:20 AM
Nomadio Sensor, V2 transeiver, temp sensor sstoffer R/C Items: For Sale/Trade 1 01-16-2007 02:35 PM
Turbo plug vs standard plug shortygy Onroad Nitro Engine Zone 5 08-13-2004 04:10 AM
