SPRING RATES and set up help >
Old 05-02-2008, 08:34 AM
Default SPRING RATES and set up help
My sons xxxt has no grip on dry loose track I need help changing the set up, The track that we run starts out wet and very tacky but with 70 to 90 entries each race day and no water it gets very dry and loose please help with set up changes during the day . THANKS FOR YOUR TIME.
HAKYLIKESRDAD is offline
Old 05-02-2008, 08:45 AM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Wat setup on it you have now. I would suggest going to a larger pin tire, Bowtie etc.
BuggyKing is offline
Old 05-02-2008, 08:48 AM
McDonough's Avatar
Tires are important. Sounds likes you might have to run different types or compounds as the track conditions change.
Ask around to see if other guys are changing tires or any other changes they are making as the track conditions change.
McDonough is offline
Old 05-02-2008, 08:52 AM
WE CURRENTLY RUN T BONZ IN RED OR RED STEP PINS ALSO RUNNING STOCK SHOCKS 35wt oil stock springs.
Old 05-02-2008, 09:15 AM
Suspended
It's been my experience that many people try and set-up their trucks and buggies and do all their practicing when they arrive at the track - when conditions are usually the best they're going to be all day - and only struggle progressively as the day goes on and find themselves lost as the conditions deteriorate.
IMHO you need to have an adjustable set-up that's somewhere between your tacky/soft start of the day and dry/loose end of the day as a happy medium and then use tires for fine tuning. Shock oil and spring choice has to be adjusted from the stock set-up - but a lot of that comes down to the track you're running and the size of the jumps. Smaller jumps, and looser tracks can handle softer set-ups - while tracks with bigger jumps require more dampening.
Personally I'd suggest to get some tires that are designed for dry track conditions like Panther Switch's (http://www.pantherteam.com/index.php...roducts_id=265) or something similar and change to them as the track dries -- and save your T-Bones or Step-Pins for when the better traction is available or when you first get to the track.
hope this helps
RocketRob40 is offline
Old 05-02-2008, 09:52 AM
thanks for your advice we will try this on sunday.
Old 05-02-2008, 10:47 AM
Trader Rating: 44 (100%+)
Camber is important too. If you are loose coming out of turns, increase negative camber up to about -2, if you are loose on acceleration, decrease the camber. Also, going to lighter weight shock oil 30wt in the rear will increase traction. Make sure the ride height is bones level rear and arms level front. If you have too much steering, try decreasing front toe to 0 degrees, if you have toe out, that could make you loose.
mattnin is offline
Old 05-02-2008, 11:49 AM
trx450racer174's Avatar
I run the new matt francis set up on my cr with orange front springs instead of red springs, Track conditions are dry and blue groove with more 1/8th size jumps and some pot holes from the buggies, as far as the tacky wet condition i dont have any experience on that type of surface so no help there.
trx450racer174 is offline
Old 05-03-2008, 06:09 AM
Thanks for your time. He has only been driving for 4 months mostly indoor carpet, now we are moving outside to dirt and we are having trouble finding grip. All of your suggestions will be tried. Does anyone have a chart for spring rates as far as color goes. Also I found a suggestion on cutting down foam tires liners to improve grip on loose tracks.
Old 05-03-2008, 06:17 AM
ChrisWolfson's Avatar
Find some of the guys that have good traction and find out exactly what tires and foam they are running. When you have no traction it is usually in the tires. Your setup is probably pretty neutral. There's no magic bullet until you get the right tires on the truck. Good luck!
ChrisWolfson is offline
Old 05-03-2008, 11:38 AM
THANKS EVERYONE We have negative camber at -2, Toe in set slightly in, orange front springs, red on rear, new front ribbed tires, new rear panther switches all with stock foams, fresh charged 5000mah batteries, and we are heading out the door for some practice
Old 05-03-2008, 12:00 PM
tmail55's Avatar
Trader Rating: 61 (100%+)
Losi Springs
1.15" 7.6 White
1.15" 8.6 Orange
1.15" 9.6 Yellow
1.15" 10.6 Pink
1.15" 11.6 Red
1.15" 12.6 Silver
1.15" 14.6 Blue
1.15" 17.5 Dark Green
2" 2.5 Red
2" 2.9 Orange
2" 3.2 Silver
2" 3.2 Green <<< wrong rate it's 3.5
2" 3.8 Blue
2" 4.1 Black
2.75" 1.8 White
2.75" 2.0 Yellow
2.75" 2.3 Pink
2.75" 2.6 Red
2.75" 2.9 Orange
2.75" 3.4 Silver
2.75" 3.7 Green
2.75" 4.1 Blue
tmail55 is offline
Old 05-03-2008, 01:05 PM
THANK YOU TMAIL55 now if I can get this to print out it will be a good day
Old 05-03-2008, 05:09 PM
tmail55's Avatar
copy/paste to notepad and print.
tmail55 is offline
Old 05-03-2008, 05:28 PM
tmail55's Avatar
Try (as the track dries) -1/2 to +1/2 degree on the rear IF track is REAL loose with a lot of dust.
30 oil in shocks.
Racing carpet is MUCH diff then dirt, he may need to learn a slower finger.
Smooth no jerks make a fast lap!
tmail55 is offline
