og bj4 info needed
hey guys im going to be picking up a bj4 non worlds. and i have some ?'s like arms do the b4 arms work front and rear. and also what all parts are ae parts. i just have to find out what parts i will need to order. i hate not having parts on hand. also how much better is the worlds over the non worlds. thanks
The standard kit is B4 arms. I would suggest getting the upgrade from JConcepts for a new bulkhead, and heavy duty arms. I can look up a part number for you, or just go to JConcepts.net. The rear arms are fine. There needs to be a little bit of work done to the right rear, so it doesn't drag on the diff housing. The PLUS of that kit is that you can use stick packs from other cars (T4 or Touring cars, or what ever). The Worlds car just has more weight on the rear with the saddle packs. The Original is still a very good car. And handles well. JConcepts still supports that car, so no problem with parts. Really, just A arms in about all you will need. The drive train is tough.
Originally Posted by afish
(Post 4349984)
