Old 04-10-2008, 05:59 PM   #1
HWYSHREDDER78's Avatar
Trader Rating: 25 (100%+)
Default Help Needed For T4 Front Axle Conversion.
I was looking at a T4 on some website and it had a T4 with a Losi front axle conversion listed in the specs.I was wanting to do this mod as it has the bearings in the hubs so I won't have to keep popping my bearings out on my wheels when I change tires but I don't know what parts that I will need to do this mod.Thanks.
HWYSHREDDER78 is offline   Reply With Quote
Old 04-10-2008, 06:04 PM   #2
kstarr's Avatar
t4 and losi truck both have bearings in the wheels . the losi buggy has bearings in the hub not the wheels. hope this helps.
byb.racing
speedysracingparts.com
banzaimotors.com
kstarr is offline   Reply With Quote
Old 04-10-2008, 07:01 PM   #3
Trader Rating: 67 (100%+)
You would not want to run the Losi buggy axles in the front of a truck as you would shear them off in every wreck. As stated in previous post the front wheels and bearings in Associated and Losi trucks are the same.
nutz4rcyktw is offline   Reply With Quote
Old 04-10-2008, 08:27 PM   #4
ta_man's Avatar
Trader Rating: 151 (100%+)
The current Losi and Associated truck front wheels are not the same - they have different offsets. You can put an Associated front wheel on a Losi truck with no modifications (it'll look weird, but you can do it), but you would have to remove part of the inner flange on a Losi truck front wheel to fit it on an Associated T4.
ta_man is offline   Reply With Quote
Old 04-10-2008, 10:30 PM   #5
Thanks guys,I really like the idea of no bearings in the wheels but it looks that I should forget about this mod.Maybe someday when a T5 comes out it will have bearings in the hubs and more user friendly shocks to rebuild.
Old 04-10-2008, 10:50 PM   #6
Trader Rating: 26 (96%+)
I would look at the firestorms front hubs. The firestorm is practicly a t-4 clone & it has then in the hub & not the wheel.
party_wagon is offline   Reply With Quote
AE B44 Front Axle Hexes X5 Addict Australia Wanted to Buy 3 03-12-2008 05:40 AM
front axle birddog24 Rookie Zone 2 12-05-2007 04:45 AM
**WTB STEEL FRONT AXLE FOR TC4** BIG DADDY8 R/C Items: Wanted to Buy 1 09-09-2007 09:14 PM
solid front axle. stumper Electric On-Road 4 01-08-2004 12:17 PM
