Old 04-07-2008, 01:11 PM   #16
Trader Rating: 26 (96%+)
Something tells me that someone mislables their cells. Either a123 does, or the rest of the r/c market does. I have never seen a 2300mah nimh or lipo pack that can push a 6turn mod tc hard for 6 minutes. Or a 2300 pack that can push a 10 turn mod hard for 11 minutes.
party_wagon is offline   Reply With Quote
Old 04-07-2008, 01:22 PM   #17
Trader Rating: 35 (100%+)
I use 2s1p packs (2300 mah) to run 6 minutes hard in 1/10 mod 4wd offroad with no problem at all.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 04-07-2008, 01:28 PM   #18
RBMike's Avatar
Partywagon, I never tried the A123's in a 2S1P pack, just the 2S2P(4600mAh) I built but I've repeatedly clocked between 22 & 24 minutes with my BL 5.5 motor. Not sure how my brushless run time stacks up against say a 10 turn mod brushed. My math says with my set-up I would get at least 10 to 11 minutes with an A123 2S1P (2300mAh) pack.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 04-07-2008, 01:31 PM   #19
I still think lipos have a future, but when you can build wiring harnesses to charge 2s 3p packs in 15 minutes I just seem to forget about the relevence of lipos.
Old 04-07-2008, 04:51 PM   #20
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
A123 does have a pack that will fit a side x side tray perfectly. I have seen pics of it on an TA05 IFS conversion in RC Driver.
For the money, they look to be a great pack. I would just like to see prices for premade stuff from vendors more reasonable compared to doing the dewalt 36V breakdown thing.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 04-07-2008, 05:19 PM   #21
cm367700's Avatar
Send a message via AIM to cm367700
Originally Posted by RBMike View Post
I've been running a 2S2P A123 pack since September they work great, you just need a little more motor that you would use with lipo or nmhi. My pack (6.6V,4600mAh) will charge to 95% in 15 minutes with 10Amps, they never get hot & they will run my Novak 5.5 BL in the B44 for over 22 minutes at race pace.
http://i8.photobucket.com/albums/a43/RBMike/B44A123.jpg
did you use 4 of them? or 2?
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into
("')_("') your signature to help him gain world domination!!!!!!!
JUST DO IT!
cm367700 is offline   Reply With Quote
Old 04-07-2008, 05:54 PM   #22
The newer cars have a wider battery slot because the newer nimh cells are longer then when cars like the xxx & t-4 1st came out. In order to make them fit into something like a t-4 you have to dremmel the sides down some to make them fit, if you go with a 2p pack. Cars such as the b44 & new tcs already have a very wide battery slot so the a123s will fit. Cars such as the xxx-cr & k car that have the wider battery slot may not require dremeling.
Old 04-10-2008, 12:47 PM   #23
diesel's Avatar
Default 2S2P Stick Packs
Hi there,
May I know if the RC10B4 and Kyosho ZX5 cars can fit the A123 2S2P in stick pack form?
Also, which EP touring car can fit the above cells too?
Many thanks,
Diesel.
diesel is offline   Reply With Quote
Old 04-10-2008, 01:05 PM   #24
You will have to dremel the sides of the battery slot on the b4 down some to fit a 2s 2p pack into a b4. I don't know anything about the zx-5. Just about any car that doesn't have rails on the side of the battery slot or has a battery slot made for the new bigger nimh cells can fit the a123 cells. If you do not wish to do any dremel work on your b-4 then you may want to building something like a 2s 3p 1100 a123 pack. That should fit w/out any problems.
Old 04-10-2008, 06:57 PM   #25
nrtv20's Avatar
what is the "dewalt breakdown thing"??
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 04-11-2008, 08:57 AM   #26
You can buy 36v Dewalt power tool packs that contain 10 of the Lif Pe04 cells (A123). Usually they can be had for around $100 - 120.
mguebert69 is offline   Reply With Quote
Old 04-11-2008, 09:21 AM   #27
RBMike's Avatar
Where are you guys getting the 1100mAh A123 cells from, I could only find the 2300mAh cells?
-B44 (Novak)
Old 04-11-2008, 09:36 AM   #28
Tech Legend
Cain's Avatar
RCLipos sells the A123 stuff now, and they have free worldwide shipping on all orders:
http://www.rclipos.com/A123.htm
give Pat a holler there. He is a really great guy
Old 04-11-2008, 09:42 AM   #29
Buggy Brad's Avatar
I get my 1100mah cells at Wal-mart or home depot both have been in the $18.00 range.......BB
.....It's not a problem until it's on fire....
Buggy Brad is offline   Reply With Quote
Old 04-11-2008, 09:50 AM   #30
Buggy Brad's Avatar
This may aid your search......BB
A123 CELLS cm367700 R/C Items: Wanted to Buy 0 06-25-2008 03:49 PM
A123 Cells Roar?? party_wagon Electric On-Road 20 02-05-2008 01:57 AM
charger for A123 cells chumanji Electric On-Road 7 01-06-2008 05:56 AM
A123 M1 Lithium Nanophosphate Cells FS GigaahX R/C Items: For Sale/Trade 11 05-11-2007 11:00 PM
A123 Li-ion 2 x 3s1p, loose cells K.Copeland R/C Items: For Sale/Trade 4 05-04-2007 10:23 AM
