Old 04-01-2008, 06:07 PM   #1
Send a message via AIM to playboy Send a message via Skype™ to playboy
Questions?? gearing for 6.5r nokak brushless
i want to buy a brushless for my b44.
what gearing should i get?
playboy is offline   Reply With Quote
Old 04-02-2008, 12:23 PM   #2
BuggyKing's Avatar
Trader Rating: 17 (100%+)
it depends on ur track ur gonna run it. I ran a 19 or 20 pinion on mine. 20 seemed to work real good. If ur undergeared the car will top out about half way down the track, and if ur overgeared it top out at the end of the straight away. U want a gear that is plenty to get u done the straight. Thats something ull need to experiment with. Hope my 2 cents helps.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 04-02-2008, 12:25 PM   #3
BuggyKing's Avatar
A smaller pinion will spool the motor faster, good for small track with tight turns, and a larger pinion will spool later in the powerband of the motor good for a track with many straights etc.
RIP Mike M
Old 04-03-2008, 08:58 AM   #4
BuggyKing has got it. For a 6.5in a B44 buy a 19 & a 20 and you should have it covered.
Stallard is offline   Reply With Quote
Old 04-03-2008, 02:06 PM   #5
RobertjDrew's Avatar
Send a message via Yahoo to RobertjDrew
playboy - For a Novak 6.5R with a 4wheel drive buggy you should have a final drive ratio of a 10. That should be a good starting point. I haven't run a B44 so I can't give you the exact gearing. Sorry. I hope this helps you out.
Later.
Robert Drew
Novak Electronics - Team Trinity - Upgrade R/C - RCID - Drew Racing
RobertjDrew is offline   Reply With Quote
Old 04-11-2008, 08:06 AM   #6
hyperguy's Avatar
Trader Rating: 22 (100%+)
ive got a 5.5 in mine and i gear mine between 16 and 17. at my local track we have alot of qiuck turns and short chutes. i would buy 18-20 tooth and test them.
hyperguy is offline   Reply With Quote
Old 04-20-2008, 09:13 AM   #7
rifleman223's Avatar
The B44 manual actually has recommended gearing. For the 6.5 a 19/84 and the 5.5 18/84. I have the 6.5 and using the 19/84, works VERY well in my local track. blindingly fast....
Associated B44.2 - Novak 6.5/LRP Flow
Durango DEX410 V3- Turnigy 5.5/LRP Flow
rifleman223 is offline   Reply With Quote
MR4-BX Brushless Gearing SoonerNate Electric Off-Road 2 02-11-2008 06:38 PM
Brushless 13.5 gearing BuggyKing Electric Off-Road 10 10-14-2007 09:33 PM
Gearing a tc3 with 13.5 brushless roadrashracing Electric On-Road 9 08-05-2007 12:32 PM
Brushless gearing ?'s 4wheeldrive Georgia Racing 10 07-19-2007 05:10 PM
7.5 brushless gearing on a T3 kingboby Electric Off-Road 3 06-15-2007 11:46 PM
