Old 07-17-2003, 05:42 PM   #1
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
Default pipe rubbing on Lexan
maybe this title will get more attention.
will the paint or lexan get messed up if it rests on the composite pipe. there is no way that I see to prevent this but is it bad????
corvettecrazy is offline   Reply With Quote
Old 07-17-2003, 06:50 PM   #2
SlobbaTech's Avatar
The lexan will wear a groove into the pipe if you don't cut enough of it off.
SlobbaTech is offline   Reply With Quote
Old 07-17-2003, 07:16 PM   #3
sorry I did explain that more. the stigner is fine and plenty of room is there for that to move but the lexan body is touching the whole pipe. FE. if you take the pipe and cover the outside with your hand that part is touching the lexan body.
Old 07-17-2003, 08:32 PM   #4
it may melt it?
NightLife is offline   Reply With Quote
Old 07-17-2003, 09:33 PM   #5
Originally posted by NightLife
it may melt it?
thats always good?!?!?!
well atleast it wont be a problem if its gone
Old 07-17-2003, 09:54 PM   #6
Can you bend the lexan a little to try to create a step or is it just totally hitting the pipe? What kind of car and what body is it? Did you put the holes for the body posts in the proper location?
Fast buggy is offline   Reply With Quote
Old 07-17-2003, 11:51 PM   #7
SlobbaTech's Avatar
On my cars the pipe might touch the body in a spot or two and it's never been melted but the paint can wear off if you don't put some tape between it. The pipe only gets up to like 150*, woudln't worry about it.
Old 07-18-2003, 12:25 AM   #8
Yeah i didnt think about that, i never remember my body melting when it touched my pipe. I put tape on my body wherever it touches the chasis so the paint doesnt come off.
Old 07-18-2003, 07:09 AM   #9
the bosy is the one that comes with the HPI NMT RTR. it looks like a take off of a toyota pickup truck.
what kind of tape would I use???
as for bending the lexan it already is formed to go around the pipe but the pipe still touchs it.
the holes are in the place in which HPI left little indents for them to be.
Old 07-18-2003, 12:40 PM   #10
SlobbaTech's Avatar
Doesn't really matter, as long it's not super heavy in weight and sticks real good. Just need something between the pipe and paint.
Old 07-18-2003, 02:41 PM   #11
Send a message via AIM to ChrisE
It shouldnt damage the lexan or melt it. It will however remove the paint. At least, thats what happened to my GT.
ChrisE is offline   Reply With Quote
Old 07-20-2003, 12:47 AM   #12
Ive used electrical tape, just make sure the body is clean before applying. The electrical tape probably wont stick forever so check on it every once in a while.
Rubbing alcohol to clean a body bigdog xxx-s Painting, Designs, Graphics and Photography 3 12-28-2007 10:27 PM
batteries rubbing Hayden Electric On-Road 4 08-01-2006 08:07 AM
CVD's rubbing scotwithonly1t Electric On-Road 3 12-29-2004 10:18 PM
Rear Tires for Xray Factory RUBBING! HELP Hypnomagic Electric On-Road 1 11-13-2004 11:03 PM
savage.21 header rubbing gunyadown Rookie Zone 0 05-14-2003 05:46 PM
