Shrinkage
Old 03-22-2008, 07:26 PM
BadSign's Avatar
Trader Rating: 15 (100%+)
Default Shrinkage
Not in the Jerry "The water was cold" Seinfeld way.
How often do you install new tires? I put new bald pink Taper Pins on the front of my truck last week (clay track) and noticed they were at least .25" larger diameter then my rears. The rears (also bald pink tapers)date back to last year and have gone through 2-3 sets of inserts. Is this normal? I keep them sealed when not racing.
BadSign is offline
Old 03-22-2008, 07:39 PM
TMXONR's Avatar
Didn't George say that.
TMXONR is offline
Old 03-22-2008, 08:16 PM
air8's Avatar
Don't put Losi pink tires in acetone either. A truck sized tire will shrink to a buggy sized tire with the quickness.
air8 is offline
Old 03-22-2008, 09:28 PM
What he said
It also seems to suck the oil out of them and make them harder.
Stallard is offline
Old 03-23-2008, 02:37 AM
I agrees, I soaked some Losi fronts truck's in acetone to change foams,1 tire stayed normal the othe looked like a buggy rear
X God is offline
Old 03-23-2008, 07:00 AM
BadSign's Avatar
Okay, that helps a ton. I'd noticed they've lost some "tackiness" as well, so that explains the problem.
And it was George Costanza. I stand corrected!
BadSign is offline
