USe Bearings For Servo Saver?
Does anyone use barings to replace bushings in the servo saver, or is it totally unnecessary? TeamAssociated says no need to do so.
Servo Saver?
9162 FLANGED 1/ 8" X 1/ 4" bearing qty 2 (replace 9155 flanged bushing????)
Thought I'd post something for all looking to upgrade T3 to bearings. The following includes responses by TeamAssociated to my query about bearings and locations:
In Servo bellcrank (replaces bushings in right side steering bell crank): 9162 FLANGED 1/ 8" X 1/ 4" qty 2
***Correct!***
In Differential:
6589 5/32 x 5/16 qty 1
***Correct!***
In Differential outdrive hub:
***Correct!***
In Tranny case
3976 3/8 x 5/8 unflanged qty 2
3977 3/16 x 3/8 unflanged qty 2
***Correct!***
In Tranny
***Correct!***
Rear Axles
3977 3/16 x 3/8 unflanged qty 4
***Correct!***
Front Wheels
***Correct!***
Optional in Associated Torque Clutch?
3977 3/16 x 3/8 unflanged qty 1
(bearing replaces 6599 3/16 x 3/8 bushing)
***Do not use a bearing here, we found it to work better with the
bushing.***
Less Optional: Servo Saver?
(replace 9155 flanged bushing)
Final Key Questions:
Are there other bearings I could use?
Can the T3 truck use a 3/16"x 5/16" Bearing? If so, where and is it flanged? (Duratax part: DTXC1413 or flanged Asc part # 6902 3/16"x 5/16")
***You have listed the primaries for the T3 truck. No others would be required.***
Servo Saver?
***Correct!***
In Differential:
***Correct!***
***Correct!***
In Tranny case
***Correct!***
In Tranny
***Correct!***
Rear Axles
***Correct!***
Front Wheels
***Correct!***
bushing.***
