Old 03-17-2008, 06:14 PM   #1
Default E crt .5
Is any one doing a e crt.5 and ifso what are you guys using for esc and motor
eric l is offline   Reply With Quote
Old 03-17-2008, 07:31 PM   #2
mamba max and a feigao 9l motor (2700 kv I think)
on 3S it's friggin quick!
artie's liver is offline   Reply With Quote
Old 03-17-2008, 07:40 PM   #3
markhat250's Avatar
Trader Rating: 65 (100%+)
Mamba Max system is cheap and easy. Not blisstering, but I have fun with mine.
markhat250 is offline   Reply With Quote
Old 03-17-2008, 07:53 PM   #4
what pinions do we use mod 1 same as E 1/8
Old 03-17-2008, 10:55 PM   #5
yup, mod 1 and get the hardened ones if you decide to keep the steel stock spur gear
one of the nice things about those L can motors, they can be had with the 5mm shaft (most mod1 pinions will have 5mm bore) if you use a smaller regular motor with the regular 1/8" shaft you'll have a harder time finding pinions and have to use a bore adapter to get the 5mm pinions to work.
price is about the same as the mamba motors too, and it's got more torque
many have had success with both setups though
one I would skip (because I tried it) the ammo $34 motor from tower 3300kv I cooked that one up real quick
Old 03-17-2008, 11:02 PM   #6
rice_man's Avatar
Trader Rating: 112 (100%+)
I did an RC Monster conversion. It's geared with a 13T hardened pinion to accommodate a smaller track. Unfortunately, I haven't had it out there to race yet. Here's a short video of the build and a test run at a local ball field.
rice_man is offline   Reply With Quote
Old 03-17-2008, 11:14 PM   #7
I have an e-crt.5 that I've done a lot of work to. I run a Novak GTB/6.5 on 2S setup and it is very good on the indoor track and surprisingly runs quite cool, but I haven't been out in the summer heat yet. A lot of guys are running the mamba max and an L can feigao motor. IMO the e-crt.5 is best if you can keep it lighter. If you want to go MM then I'd go with an S can feigao and a smaller 2S or 3S batt.
GO-RIDE.com is offline   Reply With Quote
Old 03-18-2008, 08:34 AM   #8
oh yeah, and we're forgetting
the neu 1509 motor is probably the best, but it's pricy
Old 03-19-2008, 01:46 AM   #9
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
I got told that the Mambas motors are to fast for this and will overheat easy as you can't get the proper gearing for it. What motors do most people run?
Drift_Buggy is offline   Reply With Quote
Old 04-04-2008, 05:28 PM   #10
Good Q more info on what works would be great please tell me more
Old 04-04-2008, 07:30 PM   #11
I just threw a 4800 kv motor from
http://www.medusaproducts.com/motors/036-V2.htm
into my .5
geared 14t on the stock spur gear
it friggin flys more than the 9L on 3s
seems to be a higher quality motor
Old 04-04-2008, 10:17 PM   #12
Have you had any problems with heat with the 4800 kv
Old 04-04-2008, 11:40 PM   #13
not yet, but I haven't run the thing for a full pack, just some quick shake down runs to make sure it's working properly
I may take it to the track next weekend
that medusa motor is supposed to have similar performance to the neu, but it's not quite as efficient, so it will be hotter than the nue
Old 04-05-2008, 03:52 PM   #14
What nue moror do the guys use in this .5
Old 04-05-2008, 05:02 PM   #15
These things are so loud with the steel spur....Is there a composite plastic available for it yet?
morati is offline   Reply With Quote
