Old 03-12-2008, 04:33 PM   #1
Send a message via Yahoo to mojo_23
Default how to use castle link
this is for all you sidewinder/mamba users out there. how do you use the castle link, I connect everything the esc comes on with the a yellow light, the 2 led's are on, on the casle link itself, but then the software says it can't find the castle link ? any suggestions
mojo_23 is offline   Reply With Quote
Old 03-12-2008, 04:48 PM   #2
Check if the power switch is turned off on the esc.
thisguy80 is offline   Reply With Quote
Old 03-12-2008, 05:12 PM   #3
is it supposed to be on or off, and do I need to plug in a battery pack for it to work
Old 03-12-2008, 07:18 PM   #4
You dont need a battery connected and I believe it should be turned off. You also need to install the drivers for the castle link onto your PC.
Old 03-12-2008, 07:42 PM   #5
the drivers are installed but the 2 status boxes on the main screen are red, how do i fix that
Old 03-12-2008, 07:51 PM   #6
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Set the speedo up like it says in the manual for quick setup. Once this is one disconnect your battery and have your switch off. Now hook up the usb port cord to your computer and turn on the Castle Link. Once the Castle Link is up then plug the other end into your speedo and the 2 boxes should turn to green.
ST Racing Concepts (STRC)
Old 03-12-2008, 08:12 PM   #7
beast95451's Avatar
If everything was installed correctly, all you need to do is plug into ESC, plug into USB & Castle link should pop up automatically. Unplugged from battery.
beast95451 is offline   Reply With Quote
Old 03-12-2008, 08:22 PM   #8
i thought it was but heres the wierd part, when I plug it in and go to the system folder as the website says to fix it to let it turn green, it says its another network adapter or something. when i plug the system in one light is red and the other is green on the link itself. so I tried it on another computer, but it doesnt have the internet, and it found it, i installed the software, but when i go to run it, it says the net frame stuff isnt installed even though i just did it, and the link turns solid green, i dont know what i am doing wrong
Old 03-12-2008, 09:11 PM   #9
As with any Windows machine, a re-boot is always your first step. I would then try to uninstall the Castle software and reinstall.
Castle is supposed to be very helpful on the phone, you can try calling them in the morning.
Sorry, I am not of much help.
Just for shits and grins, try a different USB port on the same puter, my didgital camera will not connect using the USB port on my flat screen, which is essentially a hub.
WobblyWheels is offline   Reply With Quote
Old 03-12-2008, 09:26 PM   #10
nitrotruckn's Avatar
Send a message via Yahoo to nitrotruckn
I am using windows vista and I have to right click the software and left click "run as administrater" in order to adjust my esc or check the settings. What version of windows are you using? As was stated earlier, castle tech is very helpful.
"For God so loved the world..." John 3:16
Team FCA Endurance
Hammer Nutrition
Team RFC- chaplain (racers for Christ)
nitrotruckn is offline   Reply With Quote
Old 03-12-2008, 09:46 PM   #11
beast95451's Avatar
Forgot about the trick for using it with Vista......
4. What are the system requirements for the Castle Link to work on a PC? Does it work with Vista?
Castle Link will work on almost any PC running Windows 98 SE through XP. It will not run on Windows 95 or earlier.
Castle Link is not officially supported on Windows Vista at this time, however, some customers have reported getting it to work by using the following method. For those using Windows Vista (32bit only, 64bit will not work), rather than hitting "run" and downloading/running the software, save the install file to your desktop. Right click on the install file that is on the desktop and choose "run as administrator". The Castle Link software should install properly after that.
Old 03-13-2008, 03:06 AM   #12
i have xp service pack 3
Old 03-14-2008, 02:01 PM   #13
it turned out to be my usb hub, it wasnt working right as soon as i tried a different hub it worked out great
Old 03-14-2008, 09:37 PM   #14
great to hear mojo! We are in Marion, Illinois this weekend at the Alpha Cup. Testing with the mamba's is proving to be a success. Currently testing the 5700 and lipo setup with good results so far. Take care!
Team FCA Endurance
Hammer Nutrition
i need a castle link hpipro4 R/C Items: Wanted to Buy 5 07-13-2008 12:12 AM
Castle Sidewinder and castle link f/s shadow102 R/C Items: For Sale/Trade 21 06-28-2008 01:22 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Link SteveJa R/C Items: For Sale/Trade 1 03-13-2007 11:16 PM
