Old 02-25-2008, 11:18 AM   #1
slow poke's Avatar
Default T4/b4 servo saver issues
Any one else had probles with the servo saver stripping on the T4.
The threaded portion does not seem to have enough material to hold the threaded nut in for more than a few runs. Any ideas on a fix/hop up, that will work?
slow poke is offline   Reply With Quote
Old 02-25-2008, 11:30 AM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
How hard are you cranking on the thing to tighten it down? You should just snug it up and it should be fine
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 02-25-2008, 11:43 AM   #3
Trader Rating: 42 (100%+)
Look at the threads closely, if they look a little flat, it's gone. Get the blue nut #9610B, it's stronger and it won't strip.
desertraton is offline   Reply With Quote
Old 02-25-2008, 11:43 AM   #4
The threads on the servo saver bolt are pretty soft. I would suggest replacing both the plastic and the bolt. Also, the factory team blue bolt works a little better, as the threads are anodized.
As OTE said, make sure you only tighten down the bolt until it is snug. You cannot compress the spring completely, as the bolt will not thread down that far. Once you go too far, you need to replace both bolt and plastic. It will not hold well once the threads strip even slightly.
071crazy is offline   Reply With Quote
Old 02-25-2008, 05:58 PM   #5
wade7575's Avatar
That's the one thing that still drives nut's no pun intended about Team Associated cars are those Dam plastic nut's.
wade7575 is offline   Reply With Quote
Old 02-25-2008, 11:18 PM   #6
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
and make sure you CA that thing together before you put it back in your car!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 02-26-2008, 09:25 AM   #7
RCBLUE's Avatar
That's what I do. I put a couple drops of CA on there and it never has a problem.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 02-26-2008, 12:59 PM   #8
Tech Legend
Wild Cherry's Avatar
Should not have to use glue ...
and
If you do glue, you can also break a servo arm or its gear`s...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 02-26-2008, 01:06 PM   #9
RCHobbyGuy's Avatar
Trader Rating: 56 (100%+)
Send a message via Yahoo to RCHobbyGuy
Default um
i used 2 ton expoy on mine and never stripped are broke a servo or servo arm
Where have all the local tracks gone i no they have closed back to my E REVOS at last i get to play with them and don't have to pay Somewhere to do so with them.......
RCHobbyGuy is offline   Reply With Quote
Old 02-26-2008, 03:47 PM   #10
slow poke's Avatar
Default Thanks for the input.
I will get another new one (whenever they are back in stock) and assemble it with a new blue nut.
I did glue the second one I stripped together to finish the day and had no problems, but I am hesitant to leave it like that since I can't seem to keep my truck off the boards.
Old 02-26-2008, 03:55 PM   #11
RCBLUE's Avatar
and
George, we're not talking about glueing the servo saver together, just using ca on the threads only, which in turn helps make a more solid surface for the nut to grab onto. I have done this since the B4 was released and first put together. Works just great.
Serpent America
Lunsford Racing
Old 02-26-2008, 06:26 PM   #12
hahaha...nope, I'm talking about gluing the servo saver together....keep the spring in there and everything but before you put the two halfs together....put some CA between them so they literally become one piece.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 02-26-2008, 07:17 PM   #13
believe it or not hes right....My tires were shaking and the truck was pushing before i glued the 2 halves. Now its fine. If you do hit anything the glue will break free and u will be able to finish race. I have spares Just in case
Bubonic-X is offline   Reply With Quote
Old 02-26-2008, 08:50 PM   #14
RCBLUE's Avatar
Ok well tha't not what I do and I've never ran into any problems what so ever. Servo saver works just find and the screw never comes loose.
Serpent America
Lunsford Racing
Old 02-27-2008, 04:57 AM   #15
happywing's Avatar
Trader Rating: 93 (100%+)
I threw the whole assembly out and replaced it with an aluminum assembly that has no servo saver like this:
http://cgi.ebay.com/GPM-AB4048-Steer...QQcmdZViewItem
I then put a small Kimbrough servo saver right on the servo:
http://www.hobbypeople.net/gallery/692131.asp
I've used this setup for 2 years now with no problems at all.
SCTE and 22T
Lovin' the Barn!
Doing the "League" at DirtBurners!
happywing is offline   Reply With Quote
Mini-Lst Servo Saver Issues! xsxracing Micro and Mini Scales 0 04-13-2008 12:24 AM
T4/b4 servo saver issues slow poke Electric Off-Road 0 02-22-2008 12:44 PM
FS: Xray M18 Kit + Micro Servo Saver, Servo and Receiver paulsrc R/C Items: For Sale/Trade 7 12-20-2007 07:38 PM
Tamiya Servo Saver with Hitec Servo old-man Electric On-Road 2 07-13-2006 07:08 AM
RC18T servo, servo saver, and steering rack Bansheeman R/C Items: For Sale/Trade 0 07-27-2005 09:27 PM
