Old 02-25-2008, 10:29 AM   #1
JAM MaxAmps's Avatar
Arrow NOW ENTERING THE RING!! At 14 OZ's THE NEW 5000 SS 7.4V WEIGHTED "SANCTION SPEC" PACK
02-23-2008, 05:54 AM NOW ENTERING THE RING!! At 14 OZ's THE NEW 5000 SS 7.4V WEIGHTED "SANCTION SPEC" PACK
"Sanction Spec" 5000 SS 7.4V Weighted Pack
Comes with 4mm bullet connectors built into pack
14 ounces(including 6 ounces of lead added to bottom)
Built in hard plastic case surrounds pack on all sides
5000+mah Capacity
7.4 Volts
45mm X 138mm X 23mm
20C Constant(100 amps)
30C Sustained(150 amps)
50C Burst(250 amps)
Comes with Apache/Hyperion Taps
Highest performance in the industry
Plug and Play for any charger/balancer/vehicle
We add the connectors and balancing taps for you
Money Back Guarantee
Normally ships within 24-48 hours
Exceeds safety standards of the IATA
Factory Fresh Cells within 3 weeks
Can be recharged unlimited times per day
Copper Tab Cells for lower resistance
ROAR Approval pending
See it here: http://www.maxamps.com/Lipo-5000SS-74.htm
Jason
CMO
[email protected]
www.NitroKillers.com www.MaxAmps.com Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 02-25-2008, 10:36 AM   #2
glassdoctor's Avatar
Oh, man.... finally got Maxamps in the OFFROAD forum. Nice
Now where is Austin?
glassdoctor is offline   Reply With Quote
Old 02-25-2008, 11:12 AM   #3
badassrevo's Avatar
Looks good, but the connectors should be on top, or have a location option.
It may be hard to use in an off road car.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 02-25-2008, 12:36 PM   #4
scrubnick's Avatar
Send a message via AIM to scrubnick
Seriously, having the connector on the side just made it not fit in just about every 2wd off-road vehicle.
KO Propo Supporter
scrubnick is offline   Reply With Quote
Old 02-25-2008, 02:00 PM   #5
Hmmm.. same problem as the new SMC packs. Too much onroad influence in r/c right now...
Old 02-25-2008, 02:04 PM   #6
Doodad's Avatar
Send a message via Yahoo to Doodad
Who's making your cells?
Doodad is offline   Reply With Quote
Old 02-25-2008, 02:06 PM   #7
Trader Rating: 26 (100%+)
Can you post some photos of the just the hard case and specs on it?
REDLINE RC RACEWAY
ldp787 is offline   Reply With Quote
Old 02-25-2008, 03:00 PM   #8
Sorry guys but the way the bullet connectors are attached to the cells to be sturdy won't allow us to use them for a top plug in format. You can get the same weighted pack with the standard wire coming out the top center or corner of this pack. Those are the options that are available. Same weighted, cased pack with Bullets built into or wired like normal. It's your option.
Jason
Jason
CMO
[email protected]
Old 02-25-2008, 03:06 PM   #9
Sorry, but nothing other than what is on the site at this time and the whole thing only adds a couple of mm's to the pack. The standard 2S 5000 is:
5000mah Capacity
7.4 Volts
45mm X 138mm X 18mm
and the SS is
45mm X 138mm X 23mm
Jason
Jason
CMO
[email protected]
Old 02-25-2008, 03:10 PM   #10
An overseas manufacturing company. We build the packs here in Spokane, WA as they are ordered to ensure that you get a fresh pack everytime.
Jason
Jason
CMO
[email protected]
Old 02-25-2008, 04:30 PM   #11
Super Moderator
Cool news, welcome the options.
But at least for our off road Losis no weight is needed. Our truck is still 2 oz over, bug is just over. Some add weight to get the same handling, we and a lot at our track seem to be having success with going softer with the suspension. Say 5wt and a spring or 2 softer all around.
Your mileage may vary as they say, and that's cool. Not trying to say anything other than hopefully add 2 cents to the discussion.
Like I said, good option for those whose vehicles aren't over to begin with, or can't get the handling comfortable.
If I may ask, where are you with ROAR certification regarding hard cases?
Cheers!
Dave H is offline   Reply With Quote
Old 02-25-2008, 04:41 PM   #12
It is a personal preference whether to add weight and how much...
A couple reasons why most guys want to add (a lot of) weight:
1. so you can run both nimh and lipo without changing handling etc. (not everyone has gone totally lipo... yet.)
2. so the setups are the same... dont' have to start form scratch and find what works.
3. so you can compare/swap setup tips etc. with other drivers.
4. so your mind doesn't play tricks on you and get psyched out that your car is messed up
Old 02-25-2008, 05:42 PM   #13
Super Moderator
Agree with every point, well except going back at all. Just trying to help with some of the changes.
I do agree completely about the mind thing. First run my Team Driver was startled by the speed increase. But by the end of the day he wanted to know if we could get more!
Last edited by Dave H; 02-25-2008 at 06:07 PM. Reason: removed extranious comments
Old 02-25-2008, 06:23 PM   #14
crazyjr's Avatar
I use the non weighted 5000's and flightpowers (3700 and 4900) without re-weighting, running stock setup w/the required 1.5oz added to rear, that B4's and T4's need. I run you're 8000's in my T4 and love them
crazyjr is offline   Reply With Quote
Old 02-25-2008, 06:58 PM   #15
Super Moderator
Please excuse my ROAR question, went back and saw it right there on the page "ROAR Approval pending"....
Get the most from a "spec" NiCD pack ? inconceivable Radio and Electronics 4 05-23-2008 09:45 PM
NOW ENTERING THE RING!! At 14 OZ's THE NEW 5000 SS 7.4V WEIGHTED "SANCTION SPEC" PACK JAM MaxAmps Electric On-Road 7 02-25-2008 05:29 PM
New "Sanction Spec" 5000 SS pack austinelse Electric On-Road 15 02-23-2008 08:23 PM
Rubber tire "ring of death" AMGRacer Nitro On-Road 6 12-01-2004 06:16 PM
