Old 03-13-2008, 07:09 AM   #16
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
thought I did post the pic as an attachment to my last post? Strange. I'll do it again after work.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-13-2008, 07:53 AM   #17
I built my own...
The Hyperion/PQ harness came from RC Lipos, the 4mm stackable banana plugs from Radio Shack and the 2mm plug from Tower Hobbies.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 03-13-2008, 09:19 AM   #18
I followed the post linked below. It was pretty simple and straightforward.
http://www.rctech.net/forum/showpost...postcount=5034
battlecat3 is offline   Reply With Quote
Old 03-13-2008, 09:19 AM   #19
tschenck's Avatar
Trader Rating: 110 (100%+)
thanks for the picture. wired it up and all is good.
tschenck is offline   Reply With Quote
Old 03-13-2008, 11:04 AM   #20
Tech Legend
Cain's Avatar
that is pretty much like how mine looks.
Old 03-13-2008, 11:08 AM   #21
tschenck's Avatar
mine is a little messier because I didn't have the stackable banana plugs. so the power wires are going straight to the balancing wires but as long as it works
Old 03-13-2008, 11:17 AM   #22
Tech Legend
Cain's Avatar
Heck, as long as it works. I didn't solder my wires yet direct, as I wasn't sure if I had everything matched up correctly. So I went ahead and connected the plug ends and ran electrical tape around them to hold them together.
Old 12-05-2008, 02:47 AM   #23
Here in Australia I have a Swallow LCB-6C balancer which I believe is the same as the LBA10 and I ordered the Maxamps http://www.maxamps.com/HYP-MULTI-GOLD.htm cable (this is available at a lot of other places) thinking it would work OK with my Trakpower saddle pack. Unfortunately that cable has a 6S size Hyperion (HP) tap plug instead of a 2S size tap (which seems to be so you can direcly plug it into one of the new HP style chargers with inbuilt balancing). So I simply rewired the 6S cable that came with the balancer (I don't intend using any 6S batteries) to use the 5 wires (at the balancer) to the 3 wires (at the Maxamps 6S plug) identical to the way the 2S connector is wired at the balancer end, but matching the location of the +/-ve and balance (ie 3) wires on the 6S end. Took a couple of minutes to pop all the wires out and redirect them. Works now by plugging the balancer red/black wires into the charger, then the rewired 6S tap into the Maxamps cable which goes onto the battery (I have shrink wrapped the other end of the red/black wires so they don't short out).
Hope that helps someone.
Cheers
gazza83 is offline   Reply With Quote
Trakpower 4800 saddle pack balancing help!! Diggity Electric Off-Road 17 12-03-2011 02:08 AM
Balancing harness=Orion lipo BAtt./Core RC charger derekride Electric Off-Road 7 08-07-2008 12:42 AM
Hyperion Balancing taps question ckaspar Electric Off-Road 9 06-13-2008 10:35 AM
Hyperion 2S tap for Trakpower/Orion - Novak Switch Jeckler R/C Items: For Sale/Trade 2 02-28-2008 06:38 AM
IS IT POSSIBLE TO INSTALL A BALANCING HARNESS meronr Radio and Electronics 7 02-26-2008 05:32 AM
