Old 02-16-2008, 10:00 PM   #1
Trader Rating: 23 (100%+)
Questions?? stupid battery questions, need help
ok this isnt really stupid but i have 3 questions on these following batteries
IB 4200 WC Assembled 6 Cell Pack
http://www.boomboombatteries.com/pro.../4200wc_6c.htm
Ener-G 4600 6 Cell Assembled Pack
http://www.boomboombatteries.com/product_p/4600_6c.htm
1. WHICH DO YOU RECOMEND?
2. (dum question #1) WHAT IS THE MAH FOR THESE BATTERIES? 4200MAH AND 4600MAH?
3. (the second dum question) WHATS THE VOLTAGE ON THESE BATTERIES? 7.2V?
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 02-16-2008, 10:04 PM   #2
Send a message via AIM to dennyboy424
Get the 4600 Assembled. Your right about the mah in your second question! Git er done!
dennyboy424 is offline   Reply With Quote
Old 02-16-2008, 10:07 PM   #3
hey denny, are they 7.2v?
i cant believe that i melted those connectors too!
Mike Adamec
Trackside Hobbies
Old 02-16-2008, 10:14 PM   #4
Yeah order those with the tamiya connector and you'll be straight! That happens. Get the bigger guage wire for your ESC and you should be fine Most people use and recommend deans which you should prolly convert to because those cant melt like that tamiya connector
Old 02-16-2008, 10:24 PM   #5
i know how it happened.....
My esc connector metal piece was out of place and fell out (the part you see was bent, that internal metal thingy)
it fell out and was sooo hot so it melted together.
Mike Adamec
Trackside Hobbies
Old 02-16-2008, 10:39 PM   #6
stew215's Avatar
Trader Rating: 16 (100%+)
Default connecters
i had the same problem with my battery connectors i went to the deans plugs and they are amazing. you will have no regret. also make sure your speed control can handle that motor the resistance may be making the connector hot too
stew215 is offline   Reply With Quote
Old 02-16-2008, 10:44 PM   #7
oh, im as basic as it gets I got the xxx-t sport rtr II and the motor and esc obviously work good together cause thats how they're assebled from losi
Mike Adamec
Trackside Hobbies
Old 02-16-2008, 10:55 PM   #8
stew215's Avatar
oo well i hope you figure this all out and all 6 cell packs are 7.2 volt each cell is 1.2 volt so just add up the cells and figure it out..
Old 02-16-2008, 10:57 PM   #9
oh lol, thanks a lot that helps
Mike Adamec
Trackside Hobbies
Old 02-17-2008, 09:43 AM   #10
Yeti35's Avatar
Get rid of the Tamiya connectors and get the Deans. The Tamiya ones were not really meant for that type of current flow hence why they melted.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 02-17-2008, 06:41 PM   #11
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
Default www.BulldawgRC.com
i agree about the tamiya connectors, they are junk. if they heat up they will melt. stick to deans connectors. as far as batteries, both are good the higher mah will increase your runtime slightly. i have some very cheap stick packs on sale, IB SC 4200'S HIGH DRAIN STICK PACKS. CHECK ON MY SITE AND THERE ARE LOTS OF OTHER THINGS ON THERE. PM me if you need help
http://www.BulldawgRC.com
Hope this helps
Bulldawg R/C Batteries and Products
Nimh and Lipo Batteries and accessories
www.BulldawgRC.com
Team Driver for: Proline, Team Epic/Trinity, Hex Crew, Bulldawg R/C, Speed Demon Hobbies ~~~~TEAM CRUNCHY~~~~
Bulldawg RC is offline   Reply With Quote
Old 02-18-2008, 08:21 AM   #12
McDonough's Avatar
The ones in your local hobby shop
Donut
Deuce Drop Racing | Team Carbon | Chad Due Circle of Trust |
S & N Trackside | www.rcscoringpro.com | www.liverc.com |
Bodies by Buck or Sarah
McDonough is offline   Reply With Quote
Old 02-18-2008, 11:35 AM   #13
if it was me i would get matched cells but for someone who does not race and just wants to have fun, then i would get a couple of cheaper batteries. all depends on what you want to do with RC.
www.BulldawgRC.com
Stupid Newbie Questions! nc racer Nitro On-Road 33 08-27-2008 02:58 PM
stupid battery question floridarcguy Radio and Electronics 1 06-01-2008 11:19 AM
Returning to the hobby after many years, a few stupid questions AttackDonut Electric Off-Road 4 11-10-2004 09:27 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
stupid battery question mech Rookie Zone 11 03-15-2004 06:51 PM
