Old 02-14-2008, 03:12 PM   #1
Revo21's Avatar
Default Brushless ammo motor and Mamba Max question.
hey im new here.my bro has a E-ZILLA (esavage) and he ordered a ammo 2600,he has the mamba ESC,do u think he will need a heat sink for the motor and a fan for fan speed controller??
Revo 3.3 with Ofna Picco .21Max
Revo21 is offline   Reply With Quote
Old 02-14-2008, 05:54 PM   #2
depends on how he has it geared and which ammo motor he's got
the ammo's have a 3 number system
should be something like a 33-56-2300
artie's liver is offline   Reply With Quote
Old 02-14-2008, 08:42 PM   #3
Revo21's Avatar
its a ammo 36-56-2600.
Old 02-14-2008, 09:51 PM   #4
oh OK,
he'll definetly need a fan and heatsink then
Old 02-15-2008, 12:41 AM   #5
Trader Rating: 34 (100%+)
Arrow
Assuming everything else, especially the wheels and tires, on the E-Zilla are stock then having a cooling fan on the MambaMax ESC is best when using a 20T pinion, a heatsink for the motor while preferable is optional.
If an 18T pinion is used there will be less heat generated by the ESC to the point where an ESC cooling fan MAY not be necessary and more of an option, a heatsink for the motor is preferable although still optional in this situation.
At the end of the day, the motor and ESC will run more efficiently given adequate cooling.
Just my 2 cents
don74 is offline   Reply With Quote
Old 02-15-2008, 07:39 PM   #6
Revo21's Avatar
k thanks,and do u think he will need two batterys,he has one Venom 4200 NIMH.Do think it will be enough?
Old 02-15-2008, 08:33 PM   #7
7.2 volts is not enough, double that would be a good starting point
but the ESC has to be rated to handle that much voltage
Old 02-15-2008, 08:45 PM   #8
Arrow 2 Batteries Double The Speed
I'm unaware of your bro's expectations so I can't say whats "enough".
A friend runs the Ammo 36-56-2600 with heatsink, MambaMax with cooling fan, 20T 32 Pitch 5mm bore pinion on two 7.2v IB4200 packs on an otherwise stock E-Savage and his Bushnell Speedgun registers a top speed of 36 mph.
Hope this helps.
Mamba Compatible Brushless motor Satish Electric On-Road 15 07-09-2008 07:12 AM
Brushless motor for Mamba Max ESC Yoshimura Radio and Electronics 10 03-20-2008 10:47 PM
Vortex 3.5 Brushless motor & Mamba ESC fasttrack42 Electric On-Road 1 06-09-2007 08:51 PM
NIB Mamba CM-20 6800 brushless motor Scottrik R/C Items: For Sale/Trade 7 04-30-2007 06:48 AM
XXX-S and Mamba brushless question Phroz Electric On-Road 9 04-23-2007 09:59 PM
