Old 02-07-2008, 05:51 PM   #1
racer34v's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to racer34v
Default Losi Front Axles / B4 Buggy
Does anyone know the grocery list i need to do the conversion... or have the parts lying around?
Alan
racer34v is offline   Reply With Quote
Old 02-07-2008, 09:28 PM   #2
It's a very simple mod. You only need the Losi steering knuckles and axles. If I remember correctly I think you have to drill the losi knuckles to fit the larger hingpins that the associated castor blocks use and do some light sanding on one side of the losi knuckles where they ride on the castor block so that they will fit in the castor blocks gap, the Losi knuckles are wider or taller within the associated castor blocks so some material on one side or the other of the losi knuckles needs to be removed to fit.
WailinOnYa is offline   Reply With Quote
Old 02-08-2008, 11:27 AM   #3
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
this is what I used (I found this on rctech a while back):
Since first running my B4 in April 2003, I have cracked numerous sets of Proline B4 front wheels. Myself and a lot of others that run a B4 at our track (CRCRC) have cracked the front, and some rear, Proline Wheels.
I have also heard complaints about the Proline front wheels not being true.
I have been running Losi rear wheels. No mod needed.
Today I ran Losi front wheels.
To complete this mod:
Parts List:
Losi A-1122 Front Spindle and Carrier
Losi A-1133 Front Stub Axles and Screws
Losi A-3016 Axle Spacers
7/64 Drill Bit
1) Drill out the hinge pin hole in both Losi Spindles with a 7/64 Drill Bit
2) Remove Left and Right Associated B4 Spindles
3) Assemble Losi Spindles: insert bearings, axle, spacer, and screw
4) Install Losi Spindles onto the B4 in place of the Associated Spindles; no spacers; Losi spindle fits directly in the Associated carrier. (Spindle could be modified to allow up/down positions by taking material off the top and bottom of the spindle and then using spacers)
5) Use one washer underneath the ball stud on the spindle. Install ball stud in spindle in same orientation as the stock B4. Use a locknut to secure the ball stud to the spindle.
6) Install wheels and tires
7) Set Steering EPA on radio
I ran this today (02/15/2004). I noticed no decrease in performance. My lap times were actually faster than last week. This mod may not be performance improving, but I donít believe that it has any negative effect on the B4ís handling.
The car maintains the same width as the stock spindle B4. It is within ROAR width limits.
Good Luck
ALL TAMIYA 4 WHEEL DRIVE ALL THE TIME
TRF-416X, SP CIRTIX, LRP X-12 17.5, FUTABA 9550
SRBMOJO is offline   Reply With Quote
Old 02-08-2008, 11:30 AM   #4
SRBMOJO's Avatar
Old 02-08-2008, 03:53 PM   #5
VOODOO+'s Avatar
Send a message via AIM to VOODOO+
The losi axle & wheel conversion is something I've done to both of my B4's and now my X-6. It's nice not have extra bearings in multiple wheels or switching bearings out when you change wheels. Losi front wheels have a slightly bigger bead area making mounting losi front tires a lot easier too.
VOODOO+ is offline   Reply With Quote
Old 02-08-2008, 05:26 PM   #6
Alltapdout's Avatar
[/QUOTE]
Lookin' Good
Nice buggy man.
Alltapdout is offline   Reply With Quote
Old 02-09-2008, 04:59 AM   #7
racer34v's Avatar
Excellent, Thanks for the information, I'll have to pick up some parts this weekend.
Alan
Old 02-09-2008, 03:38 PM   #8
VOODOO+'s Avatar
Originally Posted by Alltapdout View Post
Lookin' Good
Nice buggy man.
Thank you. It's the best buggy I've ever owned. I love the X-6!
ft b4 front axles afish R/C Items: Wanted to Buy 3 03-16-2008 04:37 PM
WTB Lunsford Titanium Losi XXX front axles S Bowen R/C Items: Wanted to Buy 2 01-01-2008 10:14 AM
WTB: 1/10 Front buggy tires for losi Johnathan R/C Items: Wanted to Buy 0 04-07-2007 08:18 PM
Losi AD2 TITANIUM FRONT AXLES, CHEAP!! Jspecrcr R/C Items: For Sale/Trade 6 02-23-2007 07:03 PM
FS: Losi Front Buggy Tires jg727211 R/C Items: For Sale/Trade 3 06-10-2005 08:50 AM
