zip free vs. buggy grip
I've always ran Zip Free on clay tracks where you run slicks or almost slicks. CRCRC or Factory Tracks are good examples. Buggy Grip is usually used on tracks where you run more of a pin, at Washtenaw or SoCal, where you run Holeshots or X-2000's.
Mixing them 50/50 is the best thing I have used.
Ever use Goof Off? I run slicks or nearly slicks on an all-clay track.
There's nothing better then running slicks and doing WHEELIES!!!!!
Goof Off is Citrus degreaser. I have never tried it on rubber but I can see how that would work. The biggest difference I noticed between Zip Free and B.G. was the B.G seemed to be more oily. If you run a track where the best traction is achieved by getting dirt to stick to the rubber then the less oily stuff seems to work better, hence the 50/50 mix. I have also tried WD40 with decent results but it doesn't work as well on wetter dirt because the leftover oil repels the water in the dirt a little.
i have never used any of these before, an i have a question, on my losi Truggy what should i use for offroad clay tracks?
btw i run losi XTT's 70% of the time & Hole Shots 30% of the time(mosly for hard packed clay tracks)
also, how do i put it on? how long do i let the tires sit? how offten do i put it on?
I think the best thing to look for when looking for unconventional tire compound is something on the label similar to "DO NOT USE ON RUBBER"!! If you see that then you probably have something!!!
With the zip, rub it in with the applicator and let it sit. The sooner the better, as it soaks in. keep applying until the tire feels tacky but looks dry.
theres also simple green been using that for about 10 years. helps get the tires sticky. also a bottle is only about 4 bucks and i just use it 100% no added water.
i use simple green to clean the tires and then use pb blaster i put it in a bingo dabber and just rub it on my tires about ten min. before my race
i usually set my cars up where i dont need traction compound..
but if one were looking for a great all around traction compound.. better than buggy grip let me know. pm me. 6.75 shipped for a bottle the same size as buggy grip. and it doesnt harm your foams.
i tried it and im hoooked i really didnt like buggy grip.
As a guy who has been in the rubber biz for longer than I care to admit, you are essentially correct. These products attack the rubber, actually breaking it down a little, reversion being the big word for the days' lesson. Thus making it a little softer and 'gummy', or stickier.
