XXXT-CR Tire Question
Can you set up a XXXT CR to run standard XXXT rims or do you HAVE TO use the quick change setup.
Thanks, James |
You should be able to. Since the A-arms from the MF2 and the CR are the same, you can just put your MF2 hubs on the arm and use the standard XXXT dogbones and axles.
