Old 04-08-2008, 10:30 AM   #46
Trader Rating: 37 (100%+)
Originally Posted by Shawn Palmer View Post
Jubilee,
You may want to recalibrate to the radio after changing the deadband %.
When the light is flickering like that, the throttle signal is fluttering back and forth right on the edge of "brakes" and "neutral". A click or two of FW trim will also turn out the light and give you neutral back.
Hmmm...I think you're on to something. If it's flickering between brake and neutral, this could be a possible cause of periodic/intermittent throttle lag...no? Come to think of it, I didn't reduce neutral % until Sat night after coming home.
I'll fiddle with it tonight and post back. Thanks Shawn!
jubilee is offline   Reply With Quote
Old 04-08-2008, 11:09 AM   #47
Shawn Palmer's Avatar
Ah - yes. Jumping around between neutral/brake can cause some "inconsistencies" in throttle operation yes.
That's why it's always best to let the ESC do as much as possible for you, and leave as much of the radio stuff you used to do for brushed motors alone. As in - drag brake, deadband, and etc.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 04-08-2008, 05:22 PM   #48
Super Moderator
If so, then yes, that sounds logical that some latency could have been creeping into the 2.4 systems. The "next gen" 2.4 systems actually use more "channels" than the originals, so instead of your 2.0 taking up 2 of the more or less 80 "channels" available (presuming no other household devices were on 2.4 nearby) the latest stuff is using 4 "channels" each. With almost everyone on 2.4 now and free to have radios on in the pits without worrying about interference, things can fill up in a hurry with a packed house.
Personally, this is why I'm really enjoying my 75mhz stuff right now - almost no one left on it, so extremely little interference issues and no latency.
Oh boy are people ever getting sloppy with radios on nowdays. Even if you are not on 2.4 you have to be careful. Many others who aren't figure everybody else is, so they can turn their radio on anytime they like. Despite the new and improved radio technology I'm having more problems than I ever had back in the day. Guess I need to dig out the old CB crystals... Breaker 19!
Dave H is offline   Reply With Quote
Old 04-10-2008, 10:28 AM   #49
Last night re-calibrated the esc/radio, no more flickering light. I'll keep that in mind for future neutral% adjustments, and report back on the intermittent throttle cuts after tonights race.
Old 04-10-2008, 11:53 AM   #50
abailey21's Avatar
Trader Rating: 36 (100%+)
Thats good to hear there was a remedy for that issue, keep us posted on throttle cutting out.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-10-2008, 09:57 PM   #51
Send a message via MSN to clintscreations Send a message via Yahoo to clintscreations
got my GT all hooked and dialed........amazed that every change with the programmer i could tell a difference
saturday wont come early enough............
i had to extend my sensor wire...........it worked will had to do untill the correct one comes in
airtronics radios - www.airtronics.net
checkered flag raceway - www.cfrkc.com
hobbytown north - gladstone, mo
kcrc - shawnee, ks
clintscreations is offline   Reply With Quote
Old 04-14-2008, 12:19 PM   #52
ZERO throttle cutting issues since re-calibrating the transmitter/esc.
I think from now on I will immediately re-calibrate after every braking or deadband change.
More and more happy with this esc!
A quick question on the Core-RC batts...I notice right after a top-off (full charge), the truck is REALLY "punchy" then gets a touch softer after the first few minutes. It's still punchy (I've never run them to cutoff) for the duration, but not like the first few minutes. No complaints whatsoever, just curious if this is unique to the Core-RC cells or to LiPo in general...
Old 04-14-2008, 04:53 PM   #53
Casper's Avatar
Trader Rating: 34 (100%+)
Anyone have offroad settings they want to share (4wd). Also gearing?
ZX5 with a 10.5 and a 5.5.
I am getting a setup for this weekends series race and looking for a good starting point to adjust from.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-14-2008, 07:33 PM   #54
abailey21's Avatar
with 10.5 run your fdr around 5.0
speedo settings really depend on the track man, drop the timing to #2 and start there check temps, you can drop the DRRS down to where you like the launch
K.C.C.O.
Old 04-14-2008, 10:17 PM   #55
Casper's Avatar
Thanks Adam. I will start from there.
Old 04-15-2008, 06:40 AM   #56
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Adam
Is there a speedo better suited for off road?
Part #
Thanks Carl
Crazy Carl is offline   Reply With Quote
Old 04-15-2008, 07:53 AM   #57
abailey21's Avatar
The version 1.1 (new ones shipping now) are already more suited for off-road.
The software changed was there to help some issues with 4 cell in 12th scale, but the DRRS was changed up so the lower numbers give a somewhat softer feel on take off which is better suited for off-road applications.
I would set your DRRS to 1-3 for off-road applications, middle numbers and higher numbers for on-road and oval applications, asphalt and dirt oval that is.
K.C.C.O.
Old 04-15-2008, 08:07 AM   #58
Casper's Avatar
Ok call me stupid. How are you guys cacluating FDR.
Spur/Pinion X internal = FDR
I can't get down to 5.0 without going to a 41 pinion then.
I am assuming you guys are using a rollout calc in there somewhere?
The internal for the ZX-5 is ~2.65 spur is 78 with 48 pitch gears.
Old 04-15-2008, 08:16 AM   #59
abailey21's Avatar
http://www.gearchart.com/
K.C.C.O.
Old 04-15-2008, 08:18 AM   #60
abailey21's Avatar
I would get yourself about a 40t pinion and your sitting on 5.17fdr
K.C.C.O.
Speedpassion GT turbosnail Malaysian R/C Racers 39 09-09-2009 04:05 AM
speedpassion GT BL speedo with speedpassion 13.5 $195.00 shipped rc_tradingpost R/C Items: For Sale/Trade 3 05-14-2008 04:28 PM
FS: Speedpassion 10.5 (Brand New) Mustangz R/C Items: For Sale/Trade 1 04-07-2008 09:31 AM
Opinions: LRP or Speedpassion xray racer Electric On-Road 6 02-19-2008 05:27 PM
LRP or Speedpassion Applesauce Electric On-Road 13 01-14-2008 10:11 PM
