Old 01-28-2008, 01:40 PM   #1
dragon26's Avatar
Default Hudy tech lathe help
Hi, I just bought a second hand hudy tech lathe and I've set it up with the tip just above the center of the comm and have it spinning the correct direction but it is leaving serrations in the comm. I'm using v guides and shimming the armature a little bit to eliminate the play.
Any help greatly appreciated.
dragon26 is offline   Reply With Quote
Old 01-28-2008, 02:24 PM   #2
MikeXray's Avatar
Trader Rating: 73 (100%+)
how much voltage are you giving it, is the arm very tight in terms of side to side play? if it moves a little this will happen.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-28-2008, 02:25 PM   #3
foolio's Avatar
Make sure it is shimmed for no play.
Make sure armature is not bent.
Diamond bit? Get one if not.
Run lathe at 3.0-3.5v.
Oil on v-guides.
Before I went brushless, I had your exact lathe and with the above setup I never had problems.
foolio is offline   Reply With Quote
Old 01-28-2008, 03:52 PM   #4
dragon26's Avatar
Default voltage
Hi, I'm running it at 4.8v as per the instruction sheet. I'm using a diamond bit. How tight should the purple retaining clips be?
I'll try running the lathe at lower voltage and check tonight.
Thanks.
Hudy tech lathe help dragon26 Radio and Electronics 4 02-01-2008 09:28 AM
Need help with my hudy tech lathe AE Racer Electric On-Road 22 01-30-2008 12:08 AM
Wtb hudy tech com lathe deedit R/C Items: Wanted to Buy 1 01-22-2006 11:59 PM
Hudy Tech Lathe f/s Art Jensen R/C Items: For Sale/Trade 1 10-27-2004 06:29 AM
Hudy tech lathe Art Jensen R/C Items: For Sale/Trade 3 07-24-2002 08:45 PM
