Old 01-26-2008, 03:03 PM   #1
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Default Wiring for lipo and nimh
So I have a new lipo that I plan on using for practice, or when allowed. I am running the JBRL and they only allow lipo and BL in Mod. Im running stock so Im using brushed and NiMH for that, but I would like ot find a way to wire them up for both. I solder direct on right now, and with lipo that doesnt seem that feasable.
So any of you out there using both, and how are you doing it?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-26-2008, 03:23 PM   #2
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Which LiPo? If you are using Orion, then you can just solder a battery tab to the end of a bullet connector.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 01-26-2008, 05:24 PM   #3
Trader Rating: 67 (100%+)
Default Wiring
I used to direct solder. Now I use Deans Ultra plugs. These plugs pass as much current as direct solder according to tests by Car Action. It is more efficient, I can switch batteries, and in case of a problem; it is easier to disconnect the power. Just my $.02.
nutz4rcyktw is offline   Reply With Quote
Old 01-27-2008, 02:23 AM   #4
glassdoctor's Avatar
Either switch everything to deans plugs, or go with a gold bullet connector setup which keeps the hardwire look
If you have a lipo with the Orion style female plugs... use a 4mmm gold conn setup.
glassdoctor is offline   Reply With Quote
Old 01-27-2008, 07:47 PM   #5
Slant EyEs's Avatar
Depending on which LiPo pack you go with, will depend whether or not you will be able to hard solder to them or not..... If you going to run Keith's packs, then you can switch to a plug, or run a carbon solder bar like some of us have....
-Jayson Pang-
Kyosho America - Peak Racing - KO Propo - AKA - DE Racing - Diggity Designs - Speedtech R/C - Team Slant EyEs
Slant EyEs is offline   Reply With Quote
Old 01-27-2008, 08:25 PM   #6
Scottmisfits's Avatar
I'm switch back and forth between NiMh's and the Orion LiPo's. I'm using the bullet connectors right on my ESC and then for the NiMh packs I use the tubes. With the Orion packs it has 4mm bullet plugs built in. Easy
Scottmisfits is offline   Reply With Quote
Old 01-27-2008, 08:29 PM   #7
K_King's Avatar
Lemme seeeee
Old 01-27-2008, 08:30 PM   #8
nc-hopsing's Avatar
Steve Butts
KYOSHO AMERICA.com -Peakmotors.com - kyoshoforum.com - Team SlantEyEs - Hardkore Paint - JBRL Off Road Series - JConcepts.net
nc-hopsing is offline   Reply With Quote
Old 01-27-2008, 08:34 PM   #9
K_King's Avatar
This is what I did, it will work for now. Who sells the Orion plugs?
http://flickr.com/photo_zoom.gne?id=2225207778&size=l
Old 01-27-2008, 09:11 PM   #10
AE 14year-old's Avatar
Trader Rating: 15 (100%+)
Kevin what up man its Zack....
im in the same boat as you but this is what I did....
Ok you know the plugs that are coming out of your lipo...well you also put those on top of your battery bars and on your Speedo wires you put the bullet plug (male) that you can have female bullet plugs on your lipo and your other packs
i tried putting a pic but its not working
im sorry
Zack Rogers...
Kyosho / Team Orion / Airtronics / Jconcetps / Amainhobbies.com / Protek Rc / BlackBeard Rc / Rcinsider.com
AE 14year-old is offline   Reply With Quote
Old 01-27-2008, 09:18 PM   #11
K_King's Avatar
Yeah but I wanted to still direct solder for now.
Old 01-27-2008, 09:41 PM   #12
ahhhh...i c....so did i but in my case(with the venom pack) i would have to solder wire to wire each time....making me have to also shrink wrap everytime so I went to the bullet plugs.....well kevin looks like your giong to mod buggy???? i take it? See ya there :
Zack Rogers...
Old 01-27-2008, 09:52 PM   #13
K_King's Avatar
Nah Im going 19T, ordered my motors tonight.
Old 01-27-2008, 10:02 PM   #14
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
Kevin, that looks like a great idea so you can run both.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
7.2 v KO servo wiring & PT wiring issues bshookup Radio and Electronics 2 06-12-2008 01:23 PM
nimh vs lipo cyrrus Electric On-Road 2 03-12-2008 12:37 AM
LiPo vs NiMH- Different perspective RCGaryK Electric On-Road 99 09-05-2007 12:17 PM
NiMh vs. Lipo chicagokenji Electric On-Road 25 09-13-2006 10:02 PM
LiPo vs NiMh…. Hayden Electric On-Road 3 06-10-2006 09:27 AM
