ASK Ronnie Gardner(Kyosho Electric Offroad)
#122
double
#123
sp2 set up
front
3b 35 dark yellow spring shock no limiters
inside on tower middle in the arm.
1 b camber link
7 degree front hubs
c front block
top hole in steering
rear
3b 30 blue spring unscrewed 2 turns
inside on tower inside on arm
2 b camber link with a 1 mm washer under ball stud on tower
e/c rear block
hubs forward
stock rear bar
diff/diff
wing middle
j concepts mid wing
17/87
memyselfandI: that was my rb5 set up. just more pack with the 3a.
turd ferguson: not a real pizza fan but the place i went with you at trackside was pretty freaking dialed.
Matt Trimmings: sigp in april fo sho!
Gitsum: i will be there tomorrow morning.
front
1 b camber link
7 degree front hubs
c front block
rear
e/c rear block
hubs forward
stock rear bar
diff/diff
wing middle
j concepts mid wing
17/87
#125
WHICH BLUE SPRINGS ON THE REAR? ALSO IS 1 CAMBER LINK (ON THE FRONT) ALL THE WAY IN OR THE SHORTEST? PLEASE TRY KINGPIN ON THE FRONT TO LET ME KNOW WHAT YOU THINK. JUST USE THE LONGEST BALL STUD WE MAKE, IT GOES RIGHT IN.
#126
Can you explain going from the 2B to 3B pistons (this is on the RB5)? My assumption is that the 3B has smaller holes but obviously there are 3 of them - so the piston will have more dampening (with the same oil), but it should be able to respond faster in rythm sections. Guessing though.... thanks
Greg
Greg
#127
Hey Ronnie what position are you running the front castor/c-blocks, forward or back in the arm?
#128
Well I had my first hit out with the SP yesterday and it was awesome... much more stable then the standard ZX5 and this thing actually steers...
Ronnie the question I have is I feel that the car needs a little more mid corner steering, around hairpins and when you accelerating out of a corner it tends to push slightly...I am running the standard SP set up.. I was thinking one rate harder rear sway bar... or maybe rising the rear outside roll centre by 1mm on the hub....or adding weight to the rear chassis... what do you recommend??
#131
dfurutani: the one means all the way in..making it a long camber link.
GMSchmidt:sounds right. i just started with the 3 hole pistons i hve not been able to test the 2 hole.
mwiley: running the front caster blocks back.
memyselfandI: try a shorter front camber link that helped me at rumble..also make sure your hubs are all the way forward in the rear...
Gitsum: thanks it was a good time.
Matt Trimmings: i have not ran the lipos in 2wd yet...
#132
#133
Ronnie I was wondering how much you would charge me to build a lumber shack to keep my RC stuff In???? Thanks 4 coming out goodtimes world of outlaws 2002 next time for sure!!!!!!
#134
jelly: im sorry i said that backwards...3a are bigger hole pistons and has less pack..sorry.
Sparky: goodtimes for sure..you should make it out for cactus...world of outlaws are on for sure next time...
