ASK Ronnie Gardner(Kyosho Electric Offroad)
#106
kstarr: its burgler...with no ham..haha
losidriver70:..thanks..had a awesome time up there racing with you guys in sac town..hope to do that again soon..
DanGriffin:6.5 has more than enough power to get the job done.
#107
Suspended
Thanks man it was great watching the SuperStock shootout
.you can hella wheel man,talk to ya later homie! Don't forget the cheese!
21 is a tad higher then 20! New track time!
2wd
Busted out a 22.9 in 4wd damn!
MINCKS IN THE HOUSE!
#109
Gitsum: ya i ran a 5.5 at cap.town but that was all i had so i think i will start with a 6.5 at runmble and have a 7.5 just in case...so much power...haha
RG
RG
#110
Hey RG, nice meeting you and Jeremy this weekend. Super fun watching you guys get it done. What are the part numbers for the carbon upper deck and battery holders on your ZX-5? Did I see carbon towers too? Also, could you please post your ZX-5 set up from Sac?
Is your RB-5 setup you ran this weekend much of a deviation from your worlds setup? If so, what changes?
#111
fraz:the carbon upper deck and chassis are not availible...and the towers were stock.
the rb5 set up i ran is on like the first page i think except i ran the tranny at normal and dark yellow springs.
i think the zx-5 set up is on the second page...i will post it again if you want.
#112
I use atomic carbon towers and a xtreme racing carbon upper deck.
The SP is a awesome car.
#113
Front:
3-B Pistons
35wt Losi Oil
Orange Front Springs
No Limiters in shocks with shock ends unthreaded 4 turns
25 degree kick-up/no spacer used
Shocks mounted in middle location on tower and outside location on the arm
2-B Camberlink with no washers under the ball stud (middle on bulkhead/outside on caster block)
Spindles in upper position
1/4oz of weight under steering rack
Rear:
3-a Pistons
271/2wt Losi Oil
Dark Yellow Rear Springs
No Limiters in shocks with New W5183-02 Shock Shafts (54mm) (The stock RB5 shock shafts are 50mm and are too short...do not use)
Shocks mounted in middle location on tower and inside location on New LA243 arm
2-B Camberlink with no washer under ballstud on shock tower brace and 1mm washers under ball stud on hub
(middle on shock tower and outside on hub)
Hubs spaced in the middle position
Hub height all the way down position
Stock Anti-Squat (2 degrees)
1 oz under rear tower
Extra Info:
Battery Position - Forward
Ride Height - 25mm Front / 23mm Rear
j concepts mid wing
3-B Pistons
35wt Losi Oil
Rear:
3-a Pistons
271/2wt Losi Oil
Extra Info:
j concepts mid wing
#115
#116
Suspended
Hey Hodapp,i met that fella at my local track this weekend,his name RG! lol
Gave us all a spanking!
#117
Set up for zx-5 sp and gearing chart.
