ASK Ronnie Gardner(Kyosho Electric Offroad) >
Old 02-13-2008, 11:40 PM
  #136
Signguy Gary:..hey gary..i will have him call you the next time i talk to him...could you send me a pm with your email..?
RonnieGardner is offline
Old 02-14-2008, 06:01 AM
  #137
revsinc's Avatar
Trader Rating: 15 (100%+)
Howdy,
What effect do the 7 and 10 caster blocks have on the car ??
cheers
revsinc is offline
Old 02-14-2008, 10:41 PM
  #138
good job at the rumble
when can i officially sign up for the burglar fanclub?
DanGriffin is offline
Old 02-20-2008, 09:57 AM
  #139
Zeke17's Avatar
Default RB5
im looking for some help with rear traction with my RB5 on clay surface
Zeke17 is offline
Old 02-21-2008, 07:30 AM
  #140
Trader Rating: 14 (100%+)
Default rear tower
Hey Ronnie, I have been breaking rear towers like I have stock in Kyosho. Now I am in Michigan and it is kind of cold at the track 55-65 degrees. They keep breaking at the top set of mounting holes. One of them broke last night after a very mild crash. I am not the only one breaking these either and it is becoming an epidemic. I want to know if the carbon rear tower from kyosho is any stronger than the plastic one? And have you tried the Atomic or Diggity carbon fiber towers? This is the only thing that breaks on my car and would like to solve this so I can drive with out fear of any small crash might break the damn tower.
mwiley is offline
Old 02-21-2008, 07:32 AM
  #141
Default rear tower
stupid server
mwiley is offline
Old 02-25-2008, 05:35 PM
  #142
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 168 (100%+)
RG...when you say 1oz under rear tower...where exactly is that going? behind the battery? or is there a secret spot that im not seeing? Thanks bud
Matt Trimmings is offline
Old 02-25-2008, 11:31 PM
  #143
markhat250's Avatar
Trader Rating: 65 (100%+)
oops
markhat250 is offline
Old 02-27-2008, 09:35 AM
  #144
Hey Ronie, thanks for the SP setup. Been looking to put a pro setup on this car for a little while now. I was really pleased with the initial kit setup, but it did seem a bit soft for my liking. Problem is, I'm terrible at trying to 'correct' the setup myself and would more than likely make matters worse if I start messing with the springs and oil. Your setup is quite a departure from the kit, so I can't wait to test it.
This was asked a few posts up, but I don't think you saw it. Which blue springs on the rear are you referring to? Is it the #68 springs? I know Kyosho just released another spring for the RB5/ZX5, but I can't remember what color and weight it was.
Laterilus is offline
Old 02-27-2008, 12:18 PM
  #145
Applesauce's Avatar
Can you post an SP Set up?
Applesauce is offline
Old 02-27-2008, 09:00 PM
  #146
theanimaleide's Avatar
it farther up on this page
theanimaleide is offline
Old 03-02-2008, 11:47 PM
  #147
Thumbs up
Ronnie Gardner Can you set up may 1/4 scale sprint car.
B.Stone is offline
Old 03-05-2008, 11:54 AM
  #148
Applesauce's Avatar
Default gearing
where should i start gearing a 5.5 in an SP?
Old 03-14-2008, 09:21 AM
  #149
B4james's Avatar
Hi Ronnie,
I want to run your loose track RB5 set up however I have been unable to buy all of the parts necessary for the mid rear conversion. What changes would you make to the set up you listed to get a similar result with the standard rear end.
We have a Nationals coming up next week and I will be running 27 turn stock and not mod so any help would be great.
Cheers
James
B4james is offline
Old 03-14-2008, 10:03 AM
  #150
Ronnie, I'm not understanding your "1-b" "2-b" settings on the camber links. Which part of your designation refers to the hub, and which refers to the diff case? also, I don't know which way you are counting (lettering) from inside out, or outside in? It isn't labeled on the setup sheets (or at least the ones I have).
