Old 01-23-2008, 09:50 PM   #16
Racerx336's Avatar
Trader Rating: 34 (100%+)
I have 2 Ice's and the Original Much More cell master with the Losi Li-po charge converter. All three chargers work killer.
Racerx336 is offline   Reply With Quote
Old 01-23-2008, 10:01 PM   #17
tschenck's Avatar
Trader Rating: 110 (100%+)
I would go for the hyperion line of chargers. If you only plan on using 2-3s you could go with the 606i (limited to 50watts). If you are going to be charging bigger packs I would get a 610i (up to 250watts). They both have built in lba10 balancers and will show you the individual cells voltage, back light and are priced well.
tschenck is offline   Reply With Quote
Old 01-23-2008, 10:22 PM   #18
glassdoctor's Avatar
Originally Posted by 22dasher View Post
never had one but theres enough chit chat talk on the net about alot of the lipo makers on the market stress not to use the MRC chargers on there batteries.
As I understand it, the 989 is different than the older MRC chargers which were terrible lipo chargers. I have read of quite a few happy 989 users. I've seen one at the track a couple times too, never heard of any trouble.
I have a couple ICE chargers... very happy with them.
glassdoctor is offline   Reply With Quote
Old 01-23-2008, 10:25 PM   #19
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by party_wagon View Post
I like my mrc 989. It can charge practicly anything & you can find them for a great price w/ a good powersuply.
I also love mine, wouldnt trade it for anything.....
They really changed the 989 and how it charges lipo compared to the older models....
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-24-2008, 08:24 PM   #20
Suspended
Thumbs up Team Orion!
What about the team orion "Avionix" lipo charger looks killer and small to.easy to pack to the track,2 orion 3600 lipo packs.
losidriver70 is offline   Reply With Quote
Old 01-25-2008, 06:29 AM   #21
Orion ran into a problem with one older model charger now they shamelessly slam all MRC chargers. The MRC 989 works great with Lipos. I have used mine for almost a year now with zero problems.
Squating Goat is offline   Reply With Quote
Old 01-25-2008, 07:05 AM   #22
If you like simple and inexpensive...I recently purchased this one. Like it so far. From RipMax......$79.99
http://www.ripmax.com/item.asp?itemi...Category=O0100
Wheelzup is offline   Reply With Quote
Old 01-25-2008, 08:11 PM   #23
The Prodigy Pro Peak II is a dc only charger, and a decent one for the price. If you shop around, you can find it on sale for 49-59 bucks.
What type of cells are in your future? Where do you charge at? I prefer the dual voltage chargers like the Bantam. But they cost more. If you only get a DC charger, then you need a battery or PS to charge on the bench. The AC/DC ones are going to cost more because they have a power supply built in.
Also consider ones with a built in balancer. I went with a bantam BC6, and it displays each cell voltage during balance charge or regular charge, cycles batteries, is compatible with stuff that's down the road (A123), etc. I think some of the Hyperions can do them also.
With that said, I love my bantam BC6. The Bantams are top of the line, and really easy to use. Second would be the Hyperions. Neu has the BC6 for 129. They also have smaller ones that are cheaper.
BC6 Specs
Runs off 11-18VDC/120-220AC 50/60Hz AC.
Nicd/MH: 1~15 cells
LiIo/LiPo/LiFe: 1~6 series
Pb: 2~20V
Charge current: 0.1 to 5.0A
Discharge current: 0.1 to 1.0A
No. of cycle: 1 to 5 times
Battery data memory: up to 5 data
Weight: 960g
Dimension: 160x120x40 mm
Mark
markw is offline   Reply With Quote
Old 01-25-2008, 10:19 PM   #24
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Rex, I just ordered the checkpoint charger.
I'll let you know how I like it when it comes in.
I was using the Orion Carbon, kinda a pain to navigate and just quit charging, need to send it in yet.
Dayton
1armed1 is offline   Reply With Quote
Old 01-27-2008, 04:29 PM   #25
BH
What would you buy if you where just getting into electric and didn't own anything but Lipo's?
and will said charger work with the smaller novak black box?
BH is offline   Reply With Quote
Old 01-27-2008, 05:17 PM   #26
Default No power supply required
Hyperion EOS0606i AC/DC Balance Charger because it is great LIPO charger, sold by maxamps for LIPO, DOES NOT NEED A SEPARATE POWER SUPPLY! Which is one less thing to lug arround and find rrom for on the bench.
DBBIndy is offline   Reply With Quote
Old 01-27-2008, 07:48 PM   #27
I own the Duratrax ICE, Astro Flight 109 and the Thunder Power TP1010C chargers. I have used li-pos for over 4 years in my off-road trucks/buggies!
The best and most expensive one is the Thunder Power 1010C and next is the Astro Flight 109 that is still probably the best li-po charger for the money on the market and the Duratrax ICE is OK and on the slow side. We have found the Duratrax ICE to also have a false peaking problem to when not hooked to a good quality power supply where the Astro Flight 109 and Thunder Power would show a input voltage fault.
The Thunder Power TP1010C has a data link cable to hook up with the Thunder Power balance to read individual cells and auto balancing feature if the li-po is over .2 volt per cell out of balance, it will cut back to .3 amp rate until balanced. Great charger!!!!
Craps is offline   Reply With Quote
Old 01-27-2008, 07:51 PM   #28
Piimpslap's Avatar
QFT
Another vote for they Hyperion, I use the same and would by another in a heartbeat if I lost or broke it.
Piimpslap is offline   Reply With Quote
Old 01-27-2008, 09:17 PM   #29
BH
someone show me a link!
Old 01-27-2008, 09:28 PM   #30
secretsg's Avatar
TME Xtrema
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMUL4
secretsg is offline   Reply With Quote
Hyperion Lipo Charger and (2) 3s Lipo Batteries RcOneNitro R/C Items: Wanted to Buy 4 05-23-2017 12:09 AM
JRXS GTB 4300 13.5 lipo charger lipo AMB joaquinriviera R/C Items: For Sale/Trade 22 09-12-2008 01:43 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
wtb orion 3600 lipo and a lipo charger nikkon R/C Items: Wanted to Buy 13 02-13-2008 10:43 AM
Lipo charger with power supply and 2 cell lipo pack fweemindan R/C Items: For Sale/Trade 3 01-03-2007 11:51 PM
